As Seen On TV Handy Stitch Mechanical Sewing Machine Logo
A
Anonymous Posted on Jan 31, 2014
I need a adapter for my singer hand stich - As Seen On TV Handy Stitch Mechanical Sewing Machine
I have Singer 457 zig zag model and the straight stich, top stich is ok, but bubottom stich is very loose. How can I fix this problem ?.
I believe it is called "bird nesting" and is actually a problem with the top thread. See, my answer to the other question you posted.
Singer 4411 skips stiches whatever stiche setting it is on
Make sure you are using a brand-new needle. A bent or damaged needle may not pick up the bobbin thread.
If you can watch the needle/hook action (open the bobbin are and hand-turn the handwheel), you may see that the timing is off. There are many web sites and videos online that explain tweaking the timing.
Singer 201K Hand Crank Sewing Machine - I have threaded machine correctly, but when stiching the threads are not interlintking i.e. stiches are not forming and thread from reel and bobbin remain loose. ...
Hi Wendy. No stitches like this is likely one of two things. The needle isn't fully inserted into the needle bar. Or it's out of time.
http://www.singerco.com/uploads/download/1297_201k.pdf
Luckily most singers of that era are similar. And there is lots of info on how to time them online.
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Singer curvy 8778 the needle is making the motions to stitch evenly, but the stiches to the left are missing, not the thread mind you. So a zigzag stich appears straight. I have done all the...
Call Singer at 1-800-4singer, sounds like a buttonhole lever problem. Is it like that on all styles of buttonholes? Check that out before you call them, and make sure that you pull the lever all the way down.
Machine skipps stiches whats wrong
You need a heavy duty needle #16 or #18 to sew leather and teflon presser foot is helpful
1helpful
Noisy when sowing stiching not at the right lenth
It may just need cleaning - check the maintenance section of the manual for how to do this.
If you need a manual, check at the Singer Company website.
1helpful
Singer 533 missing stiches
Replace your sharp needle, code 2020, with a ball point needle, code 2045. This usually solves the problem. You can also put "Stitch and Tear" at the bottom to help stabilize the material. If you can do not have Stitch and Tear, try a piece of tissue paper for the short term.
Top As Seen On TV Sewing Machines Experts
SmartAviator
SmartAviator
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
