1 Turn key in electronic ignition switch control
unit to position " 1"
2 Press the system select button (S110s3)
repeatedly until the basic display (kilometer
reading display or temperature display) is
shown in the multifunction display (A1p13)
3 Briefly press trip odometer reset button (A1s3) 3
i A signal tone sounds and the voltage
times. display appears in the multifunction display
(A1p13).
4 Press lower scroll forward/back button (S110s1)
i The "Service menu" appears in the
multifunction display (A1p13).
5 Press buttons + and
-, setting of specific
functions and volume control (S111s1)
repeatedly and select "Confirmation" menu item
6 Press lower system selection button (S110s3)
i "Confirmation" appears in the multifunction
to confirm. display (A1p13) and the menu item "Complete
service" is shown against a sight bar in the
background
7 Press lower system selection button (S110s3)
i "Service confirmed" appears in the
to confirm. multifunction display (A1p13).
8 Press the upper system selection button
(S110s3) repeatedly until the "Service menu" is
9 Using the + and
-buttons, setting of specific
functions and volume control (S111s1) select
the menu item "Special work"
10 Press lower system selection button (S110s3)
to confirm.
11 Using the + and
functions and volume control (S111s1), select
menu item "Service 3"
12 Press lower system selection button (S110s3)
to confirm.
13 Select the button + and
-, setting of specific i "Standard oil" or "Oil quality 229.5".
the specification of the engine oil used
i
If only one oil quality is approved for the
engine, no oil selection is possible.
14 Press lower system selection button (S110s3)
i The message "Item confirmed" appears in
to confirm. the multifunction display (A1p13).
Copyright DaimlerChrysler AG 10/10/06 G/09/06. This WIS printout will not be recorded by the update service. Page 1
15 Press the upper system selection button
(S110s3) repeatedly until the basic display
(kilometer reading display or temperature
display) is shown in the multifunction display
(A1p13)
16 Turn key in electronic ignition switch control
unit to position " 0"
Copyright
You can try this,
"A 'Fax Log Full ' message displays on the control panel display when the Fax Log is full."
1. Press the Setup button ("Spanner logo")
2. Press the Right arrow button (?) until Tools displays on the control panel, and then press OK .
3. Press the Right arrow button (?) until Fax Log displays on the control panel, and then press OK .
4. Press the Right arrow button (?) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
5. Press the Cancel button (X) to exit.
Hope it helps.
Hi, follow the Procedure--
1. Press the Setup button .
2. Press the Right arrow button until Tools displays on the control panel, and then press OK .
3. Press the Right arrow button until Fax Log displays on the control panel, and then press OK .
4. Press the Right arrow button until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
5. Press the Cancel button to exit.
Thanks
