The piece that holds the handle to the door is broken. I do not know how to remove the handle in order to replace this part. The fridge is about 8 years old.
SOURCE: LG Refrigerator LRBC22544st
Take off the back panel and cut the insullation as in the photo and this will never happen again. What happens is the water gets trapped and then ice forms and builds up and causes the blockage.
Sgt 48
SOURCE: Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
SOURCE: LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
SOURCE: LG LRFD22850SW light won't go out!
if you stay on the line and dont take no for an answer
they just might cover it for you
make sure you mention several times its a fire hazard
and just dont take no for an answer
