ASUS M2NPV-VM Motherboard Logo
A
Anonymous Posted on Jan 31, 2014
Doesn't boot, bios setup menu isn't open
1 Related Answer
Anonymous
  • 1812 Answers
  • Posted on Jan 19, 2011
SOURCE: Can't boot from USB on
Start and pres Del /F 2 /F10 for Setup bios .Change the boot sequence.
Usb drive 1st
Hard disk 2nd
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
Phoenix BIOS setup and help
And make a boot-able pen drive.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Hope it helps.
How to change to a different date in advanced booting options
To change your system date through Advanced Booting options, you first need to enter BIOS setup menu of your system. To enter BIOS setup menu and to change your system date, you can follow the instructions below:
1.Boot your system and enter BIOS setup menu using the designated key. Though the key to enter BIOS may vary depending upon the computer manufacturer, usually keys like Delete, F12, F10, and F2 are designated to enable a user to enter BIOS setup. To know how to identify the key your system is designated to enter BIOS setup, you can refer to the image under "Method 1 of 3: Enter the BIOS" section on the following webpage:
Important: Following link is of a third-party website. We recommend you to update your security software thoroughly before clicking on the link.
http://www.wikihow.com/Change-Computer-BIOS-Settings
2.As soon as you identify the BIOS setup key, strike it rapidly and repeatedly (while the booting is on) till the time you enter BIOS setup menu. You may get just a few seconds to do this. If you are not able to enter BIOS setup menu by pressing the key repeatedly, reboot your system and follow the same steps again to enter BIOS setup menu.
Note: BIOS menu do not support mouse input. Hence, you will have to navigate through the menu using the arrow keys on your keyboard.
3.Once you enter BIOS setup menu, you can change the date of your system by going to "System Date" option. This option is generally located in the "Main" section of the menu.
Important: The layout of BIOS menu varies from manufacturer to manufacturer but most of them share a few common settings. If you are not able to detect "System Date" option in the "Main" section of the menu, you may need to look into other sections to locate the option.
To get a pictorial explanation of the above steps, you can refer to the following link:
Hope this will resolve your issue.
GuruAid.com
How to enter bios asus on my asus v550c
On systems with Windows 8 pre-installed, you can access the UEFI (BIOS) setup screens from the Windows 8 boot menu:
  1. Press the Windows key + C, or swipe in from the right edge of the screen to open your Charms.
  2. Click Settings.
  3. Click Change PC Settings.
  4. In PC Settings, select General.
  5. Under Advanced startup, click Restart now. The system will restart and show the Windows 8 boot menu.
  6. In the boot menu, select Troubleshoot.
  7. In the Troubleshoot menu, select Advanced options.
  8. In the Advanced options menu, select UEFI Firmware Settings.
  9. Click Restart to restart the system and enter UEFI (BIOS).
How to access BIOS on an ASUS laptop
Bios setup screen doesn't apper
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup (BIOS) this will differ depanding on you computer and operating system bios
hope this helps
I HAVE AN ASROCK MB,ALIVE NF6G-VSTA, BIOS PL.50.I STARTED UP.EVERYTHING GOES BUT IT READS ON SCREEN :press F11 for boot menu,and below that it reads:single channel memory mode.IT STAYS THERE and it doesn...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
16helpful
I'm trying to help a friend install
After "Fast Boot" has been enabled, you cannot access the BIOS setup during power on . The machine will bypass "Press F2 to access Setup Utiltiy and F12 for Boot Menu" prompt.
This is a bigger issue if the hard drive crashes and access to Windows is not possible OR
Fast Boot can be enabled or disabled in the BIOS setup, or in HW Setup under Windows.
If you have Fast Boot enabled and you want to get into the BIOS setup. Hold down the F2 key, then power on. That will get you into the BIOS setup Utility.
You can disable the Fast Boot Option here. You will need to disable Fast Boot if you want to use the F12 / Boot menu.
I keep restarting my computer and everytime it came on it shows only F2: Enter BIOS Setup F10: Display Boot Menu
If you're not booting past the POST screen you're getting, then there is a possibility that one or more of your RAM sticks could be faulty. Typically, a surefire way of telling this is to open your machine up and make sure that the Ram is properly seated onto the motherboard. If it isn't, snap it down.
Hope this helps
I wanted to remove network boot from bios setup to normal cd rom boot
Hi
When you start the computer click F2 to inter the Bios setup
then go to boot menu and choose boot order make the first boot for CD Drive
there's kind of MB contain boot menu you can reach it by click F12 when you start the PC
Im trying to open the boot menu in the toshiba 2140cds but when i see the toshiba icon and press boot menu the computer does nothing:P please help
I think pressing "F10" or "F12" should show the boot menu on boot up but if this fails the you will have to go into the setup (bios) and set it there (could be the "DEL" key or "F2" for setup).
3helpful
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
How to install windows
You need the windows CD to install windows, insert the cd in drive and press enter when asked to press anykey to start from cd.
if you don't get the start from cd and the windows setup doesn't start then most likely your computer is not set to startup from a cd drive, look in the cornerts of your computer screen look for boot menu or press this to enter setup / bios
you can either use the setup / bios or the boot menu and boot from the cd.
if you use the boot menu, make sure the cd is in the drive and select the drive from the list
if you don't find boot menu or it doens't work go into the bios / setup and you will need to change the boot order to include the CD drive FIRST before hdd or floppy. consult your motherboard manual or ask me if you need help in the bios.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
