Question about HP Color LaserJet 2600n Printer
HP 2600n Ironing transfer paper jammed around top roller
Some ironing transfer paper was used in the HP 2600n printer and it has jammed around the top roller above the 4 print cartridges. Paper is going through but is badly effected by what ever is stuck to the roller. Most of the paper sheet that jammed has been removed but I can see some remnants of paper still stuck around the top roller but cant get to it. Need help identifying how to remove the cover at the top so I can get to the roller to clean it off.
Posted by tonydavis on
  • theapatrick May 11, 2010
    Did your problem get fixed? I have the same issue
Anonymous
It is probably stuck permanently, and the fuser will need to be replaced. I believe the "fuser replacement" instructions are in the manual.
Posted on Jun 05, 2009
Out put jam in the printer 2600n hp
This could be a fuser issue or a paper exit sensor issue. Please take out the fuser and check the pressure roller. Be careful, the fuser is extremely hot.
May 11, 2015 | HP LaserJet Office Equipment & Supplies
PAPER JAM - HOW DO I REMOVE SHEET OF JAMMED PAPER
The 2600s have a door in the back that can be removed to gain access to any sheets that may have become jammed. The front panel opens in two stages, the second requiring a button press on the side to gain access. Using gentle pressure and left-to-right motions you can slowly pry the trapped page from the rollers (make sure the printer is off before you begin) Some amount of disassembly may be required if the page becomes torn, but refrain from using sharp objects to pry the paper free. If you are unable to find the jammed sheet, remove the paper drawer and check the feed rollers.
Nov 25, 2010 | HP Color LaserJet 2600n Printer
Using a C3100 series HP inkjet printer, I'm trying to print HP Iron-on Transfer Paper but when I select that option, I cannot get the appropriate reverse image need for ironing on the transfer. What's...
The steps vary by printer. I've got a c7280 installed and the options for me are to click Print > Preferences > Advanced > Mirror image. When you click on Mirror image, you change it from 'off' to 'on'. Click OK to save the setting and print. Be sure to change it back after you're done printing your transfers.
I am an HP employee. I do not represent HP on this site.
Sep 14, 2010 | HP Photosmart C3180 All-In-One InkJet...
Up to what weight paper can I use in my HP Color Laserjet 2600n
Usually you can print up to about 60lb paper. You may be able to go as high as 90-110 (card stock) if the paper print path is straight thorugh. If you printer has a rear paper door then you can try heavier paper. Usually 40-60 is safe for printer without a rear door/heavy paper path.
The problem is that the heavier paper cannot bend around the rollers inside. So if it is setup to allow heavy paper it runs through flat and out the back instead of curling around and out the top as normal.
Apr 17, 2010 | HP Color LaserJet 2600n Printer
HP 2600n - Maintenance of the transer roller sheet
You can clean it using piece of paper (not printed). time for replacement - your image is very ghostly and you cant get better image after cleaning lasser/scanner assy :)
Oct 22, 2009 | HP Color LaserJet 2600n Printer
Paper Jam in HP2600n printer
Very difficult to disassemble. You should call a HP Service Center.
Jan 22, 2009 | HP Color LaserJet 2600n Printer
How to clear paper jam in output bin
The printed page comes through the hot fuser at the top of the printer, through the exit rollers an end up in the exit bin.
We cleared a massive paper jam out of the fuser, by removing the grey surround on top of the printer. The plastic hooks that hold it in place get broken in the process, then you will the jammed paper between the fuser rollers, and the exit rollers. A technician can do it for you, but is unessersarly costly.
Dec 21, 2008 | HP Color LaserJet 2600n Printer
Paper jam
That part is the fuser unit and is hot if the printer is on. Here are instructions for you. Good Luck!
http://www.laserpros.com/pdf/HP%202600-2605%20fuser-etb.pdf
Jul 27, 2008 | HP Color LaserJet 2600n Printer
Paper jam
The paper jams are in the fuser area. Which is very hot. The following is a link to change the fuser. It may be that you can get to the jam by removing the top cover.
Jul 01, 2008 | HP Color LaserJet 2600n Printer
Says paper jam, no paper inside
If you are getting a paper jam error, but no paper inside- Check your Pick Up rollers in the paper tray and then check for any stuck flags in the printer.
Sep 20, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
528 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
