We recently moved our Mitsubishi WD/65737 TV. Upon arrival at destination, we plugged in the set and got a green light then a red light for only a split second then the entire set shut down. Assuming a power supply board failure, I replaced the unit with the same results as the first time we tried to power it up. I heard a berley audible pop before all lights went out and total power failure again. What could cause the fuse to blow on two power boards?
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
SOURCE: Lamp failure indicator
I had the same issue when replacing my lamp for the first time. I replace just the bulb with the Phillips replacement bulb. After installing the power down issue started and it would take up to 7 attempts before the TV would stay on with a picture.
Since I never had this problem until i replaced the bulb i decided to send the new bulb back and replace it with a difference one. In my opinion replacement parts are never made to the same standard as original OEM parts. This TV is definitely very temperamental in regard to the bulbs.
When the second replacement bulb arrived I decided to not only replace the bulb I also cleaned the connector plug in the cartridge with a QTip and alcohol. I did the same for the plug receptor in the TV.
When I replaced the bulb i insured the the top of bulb lettering was facing the handle of the cartridge so when you put the cartridge back in the TV the top of the bulb would be facing you.
I also cleaned the entire inside of the TV where the cartridge is inserted including the screws.
Once I did all this the TV turned on the first time and has been working fine for three days now.
I do believe the replacement bulb position is very important as to how it heats up and determines when it needs to cool.
I hope this helps others with the same success i had because I really do not want to replace this TV and start replacing all the parts others have done with little to no success for this issue.
SOURCE: My mitsubishi Model # WD-60737.
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
SOURCE: I have a Mitsubishi DLP
It's not the bulb. Google Mitsubishi WD-73737 blink codes. The blinking light is a self diagnostic tool and each blink code represents a certain problem.
