I had the same problem i dropped my env2 and the inner screen went black. i tried 2 fix it but just ended up getting a new phone. you can try 2 live on the outside screen or i was able 2 bend the screen and get it to work for a while. i hope i was helpful
You really cant fix it becasue you dont have tools or proper knowledge of how to fix it. just take it to the verizon store and replace it
SOURCE: My env2 is like broken.
the black screen with the rainbow is a clear indicator that you've cracked the internal screen.
Not fixable unless you replace the screen.
SOURCE: I dropped my phone and the screen went black. My
You have damaged the delicate internal LCD beneath the more rigid touch panel......but luckily for you, it is easy to replace and rather inexpensive. Here is an example of what you need....OEM replacement with return policy.
Cut and Dry you cant mess this up, trust me......just use your head and you will feel like a real tech genius when your done. now you will be good to go and try not to drop your phone so much...:D
Good Luck and Please Rate This Post
SOURCE: My motorola rival's screen went black two days ago
i smashed mine on the wall after reading this and it worked! no dimming problems either! thank you!
SOURCE: both screens of my EnV2 are blank but phone works
i am having the same exact problem HELPPP ! i need my pictures and contacts
