I reset to factory settings, and now this. Originally had the unit set to output on component, want to set up on DVItoHDMI out. Unit appears to be tuning channels in, when I select Menu I can see programming behind menu screen, but have the constant scroll down issue so cannot make any selections. What is going on?
Incorrect language appears on the display
If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following:
CHANGE THE LANGUAGE USING THE PRINTER MENUS
1 From the printer control panel, press .
2 Press the arrow buttons to scroll to Defaults, and then press .
3 Press the arrow buttons to scroll to Set Defaults, and then press .
4 Press the arrow buttons to scroll to Use Factory, and then press .
5 Complete the initial printer setup.
CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE)
1 Turn the printer off.
2 Press and hold down and , and then press to turn the printer on.
The printer resets and starts the initial printer setup.
3 Complete the initial printer setup.
Printhead error
I only have the problem when I'm trying to output to Source A, DVI / HDMI mode. When I output to Source B, YPbPr / AV mode I have no problem. Could it be an issue with my TV or maybe the DVI-HDMI adapter? I using an old Sony Wega?
