Question about Kenmore HE2 Washing Machines
Model 110.46472500 1. Unit is POWERed on and wash cycle selected. 2. START button pushed. 3. ADD GARMENT light comes on, immediately followed by DOOR LOCKED light coming on. Both stay on. Wash cycle does not start.
IF you take the panel off the is below the door, there is a drain plug and you should take it out. YOU will get lots of WATER. Be ready. Clean this out and try again. The issue is most likely the water solenoid valve is bad or the board that controls it is bad. You can also find the tech sheet when you look for the drain. It has all the tests that you can run.
Posted on Feb 01, 2014
SOURCE: F01 and add a garment light on
Check the pump first but you most in likley have a bad circut board. On the front of the washer their is a kick panel. Remove the 3 screws on the bottom and remove it. Taped on the inside is a book of codes and some self diagnostics you can run. This is all your repairman will do and he will order the circut board and charge you more than the washer is worth.
Posted on Nov 04, 2008
SOURCE: Kenmore He2 Plus front load
unplurg your washer an wait 5minute an the door will open
Posted on Apr 25, 2010
SOURCE: Kenmore He 2 Plus washer door is locked and unable to open
unplug the washer an the door will open
SOURCE: washer will not start the "wash cycle"
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
SOURCE: Our kenmore HE 2 plus
Try to unplug unit for 30 seconds if not you have a computer issue.
Posted on Dec 18, 2010
