Question about Motorola Mobility RAZR V3xx Cellular Phone
Flash firmware - Motorola Mobility RAZR V3xx Cellular Phone
Archos 10g2 wont load up
Just flash the default firmware from the manufacturer:
http://arnovatech.com/support/firmware/2/arnova10g2/111010/update.img
http://arnovatech.com/support/updates.html?country=us&lang=en&p=2
Flashing a firmware means installing it in the device protected flash memory, more explanations here: http://www.addictivetips.com/mobile/what-is-meant-by-firmware-stock-custom-roms-and-flashing-guide/
The firmware flashing procedure for your device is detailed on Arnova web site:
http://arnovatech.com/support/firmware.html?country=us&lang=en&g=2
Jun 25, 2012 | ARNOVA 10 G2 8 GB PC Tablet with WiFi...
MAIN FIRMWARE
You can find firmware at :
http://www.akshayy.com/sonyericsson/
Hi to all. I have seen thet flashing CID52 phones has been very often nowadays, but many people are asking how to flash their phones and there is no such tutorial around the forum, so I decided to put one icon_smile.gif.
First of all I would like to tell the advantage (purpose) or meaning of flashing icon_smile.gif. Flashing the phone is procedure of putting new firmware (software) in the phone. There are many reasons to flash our phones. Firmware upgrade, solve software problems and bugs, convert our phones to some other model (most common is K800 to K810) and etc...
Flashing the firmware is done by changing the MAIN and the FS part of the firmware (while not touching the EROM and the GDFS) which makes the flashing easy procedure that can be done with the ordinal DCU60 USB cable (the cable you get with your sony ericsson phone) icon_smile.gif.
Once we know what flashing is, we can start preparing for the flashing procedure icon_smile.gif. To flash the phone means to change the MAIN and the FS part of the firmware, which means if you want to flash your phone with new one, you have to download it. Firmware and other stuff can be downloaded from here:
http://www.sek750i.pl
http://www.iprotebe.cz
These pages are free and registration is easy and fast.
First, download XS++ flashing program.
When you download MAIN and FS files for flashing, you need to download finalization files for your new firmware. There are MAAANY finalization files (a.k.a custom files or custpacks and etc...) sorted by the phone's firmware CDA numbers. To download the right one for you, you have to check your phone CDA. CDA can be checked from the service menu (>*<<*<*) where you check the firmware version. There are letters CDA followed by some numbers like 1024, 1025 or etc... These numbers are the CDA version. You have to download custpacks for the CDA you have, and the firmware you are planning to flash your phone with.
When you have all files needed you can start flashing the phone.
You need to have installed flash drivers for your phone. For beginners, flash drivers installation guide is included here:
http://www.esato.com/board/viewtopic.php?topic=150098
When you have the flash drivers installed, you can run XS++.
Before that, prepare you firmware files in one folder (I mean the MAIN and FS file unzipped in .mbn, .fbn format or whatever it is) to have them easy for accesing and navigation.
Turn off your phone. Remove the SIM card. Run XS++ and then press the "Connect button"
Then connect the phone to your pc using the USB cable while the phone is turned off. When connecting the phone to pc, hold pressed the "c"button (on the phone) pressed down. This will connect your phone to XS++, where you can start flashing it.
You will see folowing window:
New window
Press the flash radio button (As number 1 shows) if needed only. That will guide you to the flashing panel of XS++. Here you can select which firmware files you will use to flash your phone with. So check the FLASH MAIN and FLASH FILESYSTEM check boxes. Then press browse and locate MAIN and FS firmware files. When browsing from MAIN navigate and select the MAIN firmware file you have downloaded, and when browsing from FILESYSTEM, do tha same for the downloaded FS firmware file.
Then press the "Flash" button.
Now you have to wait while your phone is being flashed.
Once flashing is done, you will be prompted to unplug the phone. Then you can turn on the phone. You will get this error:
"Configuration error, please contact network operator for information". This means that your phone is not finalized. Finalizing the phone is done by uploading a pack of files into predefined folder inside the phone's filesystem structure. That pack of files is called finalization files also knows as custom files, cestpacks and etc...
Use XS++ to upload these files (you downloaded before) into this folder:
tpa/preset/custom
Use the XS++'s FSX feature to upload these files.
Here is a tutorial how to upload files to phone filesystem using XS++
http://www.esato.com/board/viewtopic.php?topic=153863
WARNING: EVERYTHING YOU DECIDE TO DO WITH YOUR PHONE IS AT YOUR OWN RISK. ME OR ANYONE ELSE IS NOT RESPONSIBLE FOR THE DAMAGE MADE TO YOUR PHONE DUE TO UNPROPER USING THE PROGRAMS INCLUDED IN THE GUIDE!!!
Hope this guide will help most of the people who are runing around the forum and asking the members for step by step flashing tutorial icon_smile.gif.
Mar 13, 2009 | Sony Ericsson K550i Cyber-shot Smartphone
Slimtype Combo LSC-24082K
Firmware Here http://support.gateway.com/support/drivers/getFile.asp?id=19715&dscr=Firmware%20Flash%20Update%20PGS3%20for%20Lite-On%2048x%2024x%2048x%20Recordable/Rewritable%20CD-RW%20Drive&uid=222228034&site=emachines
After you have downloaded the firmware update above,the Firmware flash utility,and the FlashFix and saved them all to the desk top.Run the firmware flash utility in step 1.(and follow the directions) (after you run it and make your back up,move on to step 2), Run flashfix in step 2 (and follow the directions)After you have completed steps 1 and 2 move onto the flash,(just click on the update firware file on you desktop and run it.(follow the directions n the screen)
Note: Firmware flash utility =LtnFw (use it for the backUp)
Step 1: Make a backup copy of your current firmware. You can do so using LtnFW. you should make this backup incase you decide that you want to undo the firmware flash, you will need a backed up firmware.
Note: FlashFix=flash fix
Step 2:The firmware flasher is checking your drive and seeingthat you have an OEM model and is thus refusing to flash it. FlashFix will patch the firmware flasher so that it will agree to flash your drive.
Note: Flash=The firmware file you downloaded
Step 3: After using FlashFix, run the flasher, make sure that you select the correct drive from the drop-down list, and flash
I hope this better explains the steps
Jan 31, 2009 | Computers & Internet
Any idea where to download the DI-LB604 firmware ver 1.01 ?
The following site has a 1.02 beta version of the firmware:
http://ftp.dlink.ru/pub/Router/DI-LB604/Firmware/
However, it also has the flash utility.....you could most likely save the firmware from your 1.01 router then use the flash utility on that site to flash the firmware you just saved to your 1.00 router :c)
Thanks and please take a moment to rate as fixya.
Dec 19, 2008 | D-Link DI-LB604 Router (DILB604)
Nokia 770 flashing
hi
please first download the Nokia internet tablet software update wizard from:
http://nds1.nokia.com/files/support/global/phones/software/Nokia_Internet_Tablet_Software_Update_Wizard.exe
and install it.
Then run the wizard and connect your nokia 770 when you are prompted.
The software will download the firmware, flash your device and install the fresh firmware.
Aug 30, 2008 | Nokia 770 Handheld
Sharp Blue-ray player does not reconize the flash drive for firmware updates
Format the flash drive to FAT. Extract the firmware to flash drive. Turn on the player. Reset the player to factory setting from setup menu. Inser the flash drive and update firmware.
Jul 18, 2008 | Sharp Televison & Video
T630 wont turn on after flashing
YOu can always flash? did you restore firmware after flashing? if not try to restore firmware and also write a good GDFS file
Jul 30, 2007 | Sony Ericsson T630
Motorola Mobility RAZR V3xx Cellular Phone Logo
66 people viewed this question
Top Motorola Mobility Cell Phones Experts
Vernon Taylor
Jeff
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
