The ASUS LCD monitor VE206n seems to start up OK but their is no picture. The ASUS logo comes on and the picture from the computer shows briefly. then the screen god black.
SOURCE: Cannot Find Drivers for Asus VW193T 19" LCD Monitor
there are no drivers for this monitor. you need to update or upgrade your video card.
Posted on Nov 21, 2008
SOURCE: My Asus PG221 monitor suffers from frequent issues
I'm afraid this looks like an electronic fault. Some component, most likely a capacitor, has degraded, is overheating and going out of spec.
You just might be able to squeeze some more hours of work - but the monitor is still likely to drop dead any moment now - by rigging a computer fan on the backside to extract hot air from the inside.
Possibly, the problem might have a noise factor - try adding a ferrite shielding on the cable (unless one is already there, as it often is) and see whether the thirty minutes' grace period extend somewhat.
A probably unsatisfactory solution might be to drive it at a lower resolution, so that the more relaxed frequency constraints do not stress the component so much.
When the capacitor finally blows, you might be able to recognize it and have it replaced; it's likely a US $1 component and is probably in the LCD driver section. Perhaps, just perhaps, you could already be able to see it with the naked eye looking for a component that looks "wrong" - a small cylinder that looks bloated, with electrolyte leaking, whitish powder around the base, etc. But you would still need some solder work to get it replaced - and, if it's a SMD component, chances are it can't be done at home.
Sorry for the bad news...
Posted on Oct 22, 2009
SOURCE: why does my asus monitor always read "no signal".
nah that happens with me sometimes..
have you connect the cable properly?
if that still can't make it works, first turn on your PC and monitor..
then plug off the cable that power them, so that your computer and monitor will suddenly off..
plug it on again, then your monitor will work again..
that works on mine cause my CPU is too old and had a power problem..
Posted on May 07, 2011
Nov 13, 2014 | Computers & Internet
Jan 31, 2014 | ASUS LCD Monitor
Nov 26, 2017 | ASUS Ve205n 20" Widescreen Lcd Monitor
Sep 02, 2011 | Sony VAIO VGN-SZ430N/B Notebook
Mar 05, 2010 | BenQ FP222W LCD Monitor
Oct 10, 2009 | Dell E176FP 17" LCD Monitor
Jun 18, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Apr 09, 2009 | ASUS P4P800S-X (610839118175) Motherboard
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
May 12, 2008 | Gateway FPD2275W LCD Monitor
24 people viewed this question
