I cant get restore with f4 or even into my bios...cant remember my password to my samsung netbook n130
SOURCE: what cable connects my netbook to my tv?
Most plasma/LCD's have a PC monitor plug on it. Most laptops will have one too. (or even DVI, which is usually a white plug, and wider than the VGA cable)
Either way, i'm confident that you'll probably have the BLUE 15-pin standard VGA on the monitor and the computer. If so, buy that. If you have the wider white (DVI), it'll be even better!
SOURCE: On switching on samsung n130 netbook we get a
If your ntldr is missing then Windows cannot start. You will need to restore your Operating System to correct this error.
SOURCE: How do you restore factory settings on a Samsung
with netbooks this is different as there is no CD drive. When your machine starts up you can see if there is an option in F8, F2, F11 try these, while it boots up keep pressing one of these untill a screen appears and it may give you the option somewhere there to restore?
SOURCE: got a samsung N130 netbook. it powers up but the
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
SOURCE: Samsung N130 netbook I can
Hello, Look for the screen splitter key Try to press the Fn key + screen splitter key
According to me you can use windows xp installation disk to recover your password. If you don't have windows installation disk then you can use stellar phoenix password recovery software to do so.
