Question about Entempo Spirit 20 MP3 Player
Okay i had the same mp3 but the problem was the charger.. not the mp3... so i got a new charger.. and try to even get one for the wall instead the computer.. because they cost about the same and the one for the computer is not all the great in quality.
i hope this helped you at all..
yours, Charisma , age 14
THANKS
Posted on Jun 13, 2009
SOURCE: spi video mp3 player
there is a button on the bottom of the player that slides from on to off. When the switch is turned to on press and hold the center button on the face of the device.
Posted on Aug 27, 2008
SOURCE: spi mp3 player- file system error
woo it happened to mee to! heres how to fixit!
1.go to the main menu
2.go into SETUP,
3. go down to SYS TOOLS, and go into it.
4. go to reset
5. confirm reset
6. it MAY delete all songs on your mp3, but you can easily get them back on, and WALLA itl work.
Posted on Apr 11, 2009
SOURCE: My Spi Mp3 Player Says File System Error On The Files.
maybe try and format it, that would be my guess
Posted on Aug 02, 2009
SOURCE: charging mp3 player
If your MP3 has an inbuilt Li-Ion battery (e.g. no compartment for a standard/Ni-MH AAA battery), then connecting the player to your computer will normally charge it - this is the case for the PD-6070 'stick' player.
Your player will also indicate that it is being charged (or not charged!) via the battery level/power indicator which is located on the top RHS.
Hope it helps!
Posted on Dec 20, 2009
SOURCE: My little sister's Spi mp3 player won't turn on
If you are saying that you had it plugged into a computer, and the first time you used safely remove hardware, and the next time you did not.
Then the device was in the read state and is stuck, you can remove the battery, then put it back in, then turn off the computer, turn on the player
(if it is not working ) plug it into the computer with it turned on, and start the computer, after the computer has loaded windows, check to see if the devise is listed under my computer, if it is try the safely remove hardware and see if it works now.
Posted on Feb 13, 2010
