The neck at the bottom of the ice maker chute builds up frost which gets knocked off when the freezer door is opened. The ice maker works fine and the temperatures seem ok.
I need you to confirm your model number. Is MZD2665HE correct? The problem is very likely a broken 12565502 Dispenser Door Spring or more providing you have the correct model number. There may be a kit if the model number is different.Thanks, John Tripp Appliance 911
SOURCE: Ice maker
Can you open the door by hand or is it stuck shut? Check this site for a diagram of the area to help you see inside the door mechanism. http://www.partselect.com/MultiModels.aspx?ModelNum=MSD2756G&searchTerm=img_A58-10&RefineSearch=0&imgMfg=Maytag&Page=2
SOURCE: Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, Catriver..post back.
SOURCE: frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
SOURCE: Ice dispenser
I fixed it by replacing the solenoid that operates the flapper door and the flapper door. They came as a kit and both were broken.
I still have a problem which is a bad circuit board. I can't switch from ice to water. I am stuck on ice, so I have not bothered to fix.
SOURCE: ice and water dispenser for Maytag H20 not working
Ice 2 0 ...lights flashing and ice door flapping... i called 1-800-4maytag like someone else suggested.. they are sending me new high voltage board for free..and they will install it for free.. even though it is 2yrs old.. for once someone stands behind there product..
