The sound was quiet on max volume, now no sound
SOURCE: very low sound acer aspire 5611
I have had that problem quite often. Then I usually make use of the EQ settings in the AUDIO program to BOOST the sound.
SOURCE: I own Aspire 7720, the max volume setting is real
first thing try to hook it up to external speakers see if you gain any volume that way. this would make the difference if it was the sound card or a short in your speakers if this doesn't work......
go to the manufactures site and get the latest driver available, this all could very well be the product of a corrupted driver, so here are the steps to take
What you want to do is go to device manager:
you might not have to go through that many steps, but get to the device manager find the tab for audio and then right click and uninstall your audio device. after you do that do a restart so any remnants are removed.
When you log back into Windows it will say it found the new device and this is when you install the driver you just obtained. try these steps and you should see some results, if not your issue is deeper than a software glitch, let me know what you find and then we will take it from there
