we have a message that says the black toner is not installed - and it is - how do I fix this?we have a message that says the black toner is not installed - and it is - how do I fix this?
You can't post conmments that contain an email address.
If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
in your cartage have green cheap or fuse these are reseter. the are aviable in market .change it . then your printer can work. when are u getting tonner low. recently u shuld fill cartage. i think you get empty message. just reseting cartage by new reseter than u can change old reseter. u can 100% solve your problem thanks
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Your indication regarding the 100% does not necessarily indicate a damaged chip (sensor). Many chips do not work by actually sensing the toner but by usage or other tricks. We cannot be sure about what happened but replacing the drum and affected items should solve the problem. Needed parts may be found at
