This usually means that the motor in the lens is being hindered. Was it dropped or hit hard when the lens was out last? The last time I encountered an issue like this it required the camera to be taken apart and looked over.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Kodak said, this error may be caused by your batteries as they may be dying or simply
underpowered. High Powered NiMh are recommended by Kodak. You might want to check the link and think about it.
Hi!
Sounds like we have the same problem but mine says lens error 221,0,0,0 and my daughter dropped mine. If i dont get an answer soon, im sending my in for repair, it will only cost me $50.00. Here is the website incase you want to fix yours :) WWW.Kodak.com and just click on the repairs and services. Good Luck!!
