GE 29875GE Digital Answering Machine Logo
A
Anonymous Posted on Jan 31, 2014
Bt 7600 extend phone ringing
After only 3 rings!
1 Related Answer
Anonymous
  • Posted on Jan 14, 2010
SOURCE: Can not get the answer machine to come on when the
Problem solve. Thank you for your help.
How do i extend the rings before the answer machine cuts in on my BT6500
Set the answer delay
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press (Calls) until Settings is displayed, press Select.
3.Press (Calls) to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use < or > to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Set the maximum message length
You can set the maximum length that an answer
machine message can be: 1 minute, 2 minutes or 3
minutes. The default setting is 3 minutes.
Select.
3. Press (Calls) to highlight Ans. & record and press
Select.
4. Press (Calls) to display Max. msg length and then
press < or > to select the length you want and
Billy from Hayward
It is in the owners handbook page 45 get it while the link last
http://www.shop.bt.com/content/uni2/documentation/8h3h/bt6500_user_guide.pdf
Re phone BT6500, how does one increase the number of rings before it goes to answerphone?
Hi
I give below the step by step procedure for changing the number of rings the phone will sound.
Select.
2. Press until Settings is displayed, press Select.
3. Press to highlight either Ans. & record or
4. Answer delay is displayed, use or to display
Be aware though that the number of rings needs to be less than your ansaphone service, for BT 1571 this is 5 rings, although more may be possible if you can get BT to change their 1571 for your line.
For more information about your phone you can download a pdf format manual from here:
https://www.shop.bt.com/content/uni2/documentation/8h3j/bt6500_user_guide.pdf
This can be saved to hard disk for future reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
How do I extend the ring time( number of rings or seconds)
If you press the 'menu' button on the top right side of the keypad it should open up the menu settings allowing you to set the number of desired rings. If the phone was recently purchased there may be a manual to look at for instructions. Good luck. :-)
1helpful
How to extend ring time
you have to program the phone to how many rings before the voice mail. Set it to 5 rings.
2answers
Extend ring time
this feature is set by your carrier. Call customer service and ask them to extend rings to 6 - 8.
My phone only rings 3 times for incoming calls
There is no such option in motorola as i know to extend duration of incoming ring.
2helpful
BT Freestyle 2200 - my phone is linked to an answermachine at hom
It is possible that you accidentally turned off the ringer.
Here are the instructions for the ringer on the BT Freestyle 22000000000.jpg
2answers
My BT Verve 450 digital phone set won't ring out /incoming call
bt cordless phone i have pressed something and it has locked can anyone tell me how to unlock it
BT Freestyle 2200
I think the internal ringer is a default and cannot be changed, but the external ringer can be changed.e03e2a2.jpg
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
