Question about Sony Xplod XM-554ZR Car Audio Amplifier
I HAVE STEREO sONY Model:CDX-GT260S installed in my with a round xplod speaker. I would like to add up this an amp with this stereo to good output. Will it be successful if used an amp without sub wo
Need to know which amp can support can support sony stereo CDX-GT260s
5 Related Answers
Anonymous
SOURCE: Sony xplod 52wx4
how do yoy set the clock , I do not have a remote
Posted on Sep 01, 2008
s60six
  • 328 Answers
SOURCE: how do i set/adjust the clock for my Sony Xplod car stereo?
http://audio.manualsonline.com/manuals/mfg/sony/cdxgt310_cdxgt31w_1.html
click on get manual......the clock set instructions are on page 5
hope this helps.................Good luck!
Posted on Dec 29, 2008
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: wiring problem
Power wires are as follows -
Red = Switched power (ACC)
Yellow = Constant power
Black = Ground
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Posted on Mar 19, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: How to install Sony Xplod XM-1652Z Car Audio Amplifier
First you will need to post the # of voicecoils each subwoofer has, and their resistance.
Next - you can purchase an amplifier installation kit just about anywhere that will supply you with everything needed to wire up 1 amplifier.
Power wire w/fuse
Ground Wire
Remote Wire
RCA cables
Speaker Wire.
CLICK HERE for your manual.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 24, 2009
Anonymous
  • 31 Answers
SOURCE: the overcurrent light on my sony xplod amp
Contact eric @ Capital Audio & Electronics Repair in Tallahassee,Fl 850-339-1130 we repair all namebrands & models
Posted on Mar 20, 2010
Sony xplod stereo wiring diagram
Yes you need to turn on the BOSE amplifier in the car to hear the sound. The wiring diagram is actually on top of the factory radio
You will need a 12v trigger to turn the amp on. this is assuming you have all the speaker (inputs) connected to the output from your new deck.
1helpful
How do I get faceplate off sony 52wx4
52wx4 is not the model number of the stereo...it is just purely stating the power that the stereo can handle...which is 52watts x 4...2 front speakers and 2 rear speakers...52watrs going to each
Sony XPLOD CDX-GT200 CD Player keeps going back to demo mode
This is happeneing because the stereo does not have a battery power connections. The yellow wire is for a constant 12 volt connection. This connection is for the stereo's memory.
I got Sony Xplod XM-ZR704 700W 4/3/2-Channel Car Stereo Amplifier and 12" sub. it play good for continuous 2 hours but after that starts tripping and goes on off. i checked all wires and connections.
Amp is probably over heating. Make sure the ohm load of speaker is good for that amp. This amp is not really built to handle a bridged 2 ohm load. Make sure ground wire is clean and tight to the body chassis.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
I dnt know how to hook my sony explode cdx gt 200 to my honda civic hatchback 94
The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
2helpful
IPOD to Sony Xplod CDX-S2000 CD-R/RW EQ3
you car stereo doesnt have any aux inputs you can check up more on this site
http://www.crutchfield.com/p_158S2000/Sony-CDX-S2000.html?tp=5684&tab=features_and_specs
the rca inputs are for a pre amp or an amplifier
I need a color code for a Sony Xplod CDX-GT23W.
Guessing that you don't still have the owners/install manual.
On the back of the head unit there should be a group of unused/unconnected wires (with any luck they will be marked), one or more might be an amp turn-on or power antenna lead, so I suggest (with the unit turned on) testing each wire with a DC voltage tester so as to identify and separate any leads supplying 12+ volts. the remaining group will consist of speaker leads. Trial and error testing will determine the proper L & R rear speaker leads.
Good luck
Aduz
Sony Xplod stereo reset problem
My xplod deck wen I click on source it doesn't have aux anymore? How do I fix it so I can use my aux once again
Sony Xplod XM-554ZR Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
