Question about Targus AKB33US Bluetooth Wireless Keyboard
My device says "this keyboard can only be reconnected from the keyboard side"
Then it says "please type a key on the keyboard to reconnect
Posted by robbie lee on
  • 1 more comment
  • GI Consulting Sep 09, 2014
    Hi robbie, There are several things that could be going on with it. Are you connecting this to a computer, a tablet, like iPad, etc.?
  • Anonymous Sep 15, 2021
    Hyjacker, anon 2021
    the keyboard has batteries, and must be fresh. or it will mess up or be dead or lie to you.
    Targus AKB33US Bluetooth Wireless Keyboard???????????? this KBD"
    does you android tablet have working blue-tooth, is the tablet under 33 feet away.
    the manual is lame as is the screen errors. but is bluetooth failing.
    https://cdn.targus.com/web/us/downloads/...
    batteries are always first, never to be ignored, fresh is best.
    or may be its why of telling you it went sleep mode. so click ok, and hit keys. now.
    the word "only" implies to me the KBD went to sleep mode, and only IT can exit that, (do as it told you)
    hit keys, end sleep.
Tariq Aziz
Selection dial
Turn to choose a Bluetooth wireless channel or device
Cradle
Holds phone or tablet at a comfortable angle
Shortcut keys
Function keys
Connect buttons
Press to pair with Bluetooth wireless devices
Status lights
Indicate state of Bluetooth wireless connection
Split keys
Effect changes depending on connected device
Posted on Sep 15, 2021
How to stop anti theft device activation
Unlock car, disconnect battery and leave fo 10 mins. Reconnect battery and see how you get on
2answers
Wireless Keyboard HP RK713A not typing correctly
Try going to Device Manager. Right click on the Keyboard and choose Properties. Click on Update Driver as it might find something (let it look online also). Reboot the computer. If that doesn't work, go to Device Manager, right click on the keyboard, choose Uninstall, and reboot the computer. When the computer starts up and sees the keyboard and loads a driver(s) for it, it might fix it. Good luck.
Some of my fujitsu laptop keyboard keys are not working. But the external keyboard keys are working. Can someone please help me.
Disconnect the keyboard from the motherboard and then reconnect to the motherboard. If this does not work then the keyboard may be faulty and will require replacement.
My key board is not typing the letters entered if i type f h comes up
First thing is restart your PC
if the problem persists then check this similar keyboard in other PC
reconnect the keyboard with the PC
if the problem persists the keyboard is faulty.
When i am typing , the keys are automatic got a space even i didn't using the space bar .
Hi Friend, In this case i would recommend you to please try connecting the external keyboard to the system and check if you have the same issue with the external one as well.
If the external one works fine then I believe there is a need to reseat ( disconnect and reconnect) the keyboard.
How to reconnect a keyboard for a laptop
Just out of curiosity, what do you mean by "reconnect"?
Did you physically disconnect it? To correct this, put it back in the slot for the keyboard data strip by pulling up the plastic pieces on the sides of the input and placing the data strip inside and pushing the plastic back down.
But I am assuming you mean reconnect via your actual operating system.
The easiest way is to enter the device manager, either through Control Panel on Windows Vista & 7 or through Control Panel, System, Hardware, and then Device Manager.
A tab should be available for Keyboard. You may see a Yellow Triangle with an exclamation point, meaning that the driver is messed up. Double click on the Keyboard device button and go to the Driver Tab and Choose to Update the driver, and then choose automatically to search for updates. If your driver is already up to date, and you recently did a windows update, choose to rollback the driver instead.
I hope this helps you, if it does not, I apologize and hope that you may solve your problem.
1helpful
Keyboard locked shown by symbol of keyboard top left of screen with a key by the side of it
Shut down the PC, disconnect the keyboard from its port, reconnect the keyboard in the same place and restart the PC.
Mx3200 keyboard stoped typing
Unplug the USB (or PS/2) plug for a couple of seconds and reconnect them. That worked for me when this happened on my older Logitech keyboard.
Wireless belkin keyboard
Hi. I have just worked out how to solve this as I had a similar problem. When you change the batteries of a Belkin Wireless Keyboard model F8E332ukBNDL you need to reconnect the keyboard to the wireless receiver that plugs into the USB port. To do this you press the 'Connect' button on the receiver and also press the green LED connect light at the top right of the keyboard - the one that flashes each time you press a key. I'm not sure in what combination you press these but I pressed them both and it worked.
1helpful
2answers
Wireless Keyboard not connecting
Check driver for it
  1. right click on my computer
  2. click on properties
  3. click on hardware
  4. click on device manager
  5. click on mic & other pointing device
  6. click on(+)
  7. then right click mouse
  8. click on update driver
  9. select second option in window(advanced)
  10. then click on( search removable.......)
  11. then insert driver cd in cd rom
  12. And click on Next option
If you have done this then do this
  1. if it is not work then do above procss and select third option(Don't search.I will...............)
  2. And click Next option
  3. click Next option in next window.Thats it
Hope this solution works
Targus AKB33US Bluetooth Wireless Keyboard Logo
Top Targus Computers & Internet Experts
Raj Patel
ADMIN Canada
ADMIN Canada
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
