Hdmi used to work ok then a hdmi splitter in which didnt really work to well so removed and now both the hdmi inputs are not working ? surely both could not be faulty unless they are both on the one circuit board type
Well technically 2 ports can be on the same circuit even if there split. Since you cant use both at once it makes since it would work for either or or. I am confused on your problem. answer these for me please?
why did you need a splitter if you have 2 HDMI imputs?
what are you pluging in into the t.v?
I look forward to helping you.
Testimonial: "2 inputs are not simply not enough these days everything is hdmi now. It's the same with my other 2 rooms tv's people need more than 2 hdmi inputs at least my newest smart tv has 3 , for this one though i sometimes used a sky box, x box 360, ps3, ps4, hdmi pc, apple tv, i did not use scart cables as scart quality is terrible especially with sky,i could use vga for a pc if needed but ps4 is hdmi only. Anyways basically the hdmi switch did not work properly but now no hdmi input will work but the leads are ok and the av settings on tv are ok. Looks like the hdmi board must be faulty now in the tv if there is a separate board it was a dear enough tv when bought about 5/6 years ago but i can only imagine my anger if this switch had did this to my main 50" in the livingroom these cheaper switches should be banned if they can damage tv's :("
