Question about Canon ImageClass D880 Copier
Balck horizontal lines on copies - Canon ImageClass D880 Copier
Posted by Jan Crichton on
Why does my pictures on my nikon D70 comes out balck and withpink horizontal lines
Do you see coherent photos in the camera's rear display when the CF card is still in the camera?
Aug 16, 2014 | Nikon D70 Body Only Digital Camera
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
A black line appears in the copy
if the line on the copy is horizontal(when copy comes out the line should look horizontal) ; change drum cleaning blade. if the line is verticle change the drum.
Dec 28, 2010 | Canon imageRUNNER 400S Copier
SEVERAL BLACK HORIZONTAL LINES ON COPIES
You need to locate the source of strikes.
1) remove toner crg., if it has black lines or dirts on drum replace drum.
2) check/clean copy glass
3) use flash light to check fixing section ( Left sideway of copier small doors ) if damadged replace fixing assy.
Jun 30, 2010 | Canon imageCLASS D320 Digital Copier
My copies are coming out with a horizontal black line through the middle of the page. I have a cannon C330D copy machine. And would like to fix this myself if possible. Any suggestions?
If you can wipe off the line with your hand its probably your fuser roller or pressure roller thats need to be changed. IF the line is fused properly and cannot be wiped away you might have a damage drum unit.
Jan 27, 2010 | Office Equipment & Supplies
Ghost lines horizontally (looks dirty) when making multiple copie
Check the cleaning blade of the OPC drum,the image transfer unit.
Aug 17, 2009 | Canon Office Equipment & Supplies
Workcenter m151
Not enough information......
Does the problem when copying on the glass...through the document handler....printing...is there part of the information you expect to see there with the black lines over the top, or JUST the black lines ?
Jul 17, 2008 | Xerox WorkCentre M123 Copier
Shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
Jul 12, 2008 | LG Flatron L1710M 17" LCD Monitor
Copies print with horizontal lines
thin lines? spaced about 1.5 inches apart could be toner left on the drum, take the cartridge out turn it over and retract the shutter, manually turn the drum using your thumbs on the edges of the drum, do you see thin lines on the drum? sometimes something sticky gets on the drum attracting toner and then it transfers to the paper during the copy process
Dec 20, 2007 | Office Equipment & Supplies
Canon ImageClass D880 Copier Logo
43 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
