On my Toshiba 2573db tv, the sound from the normal channels carries
over to all of the ext. channels. When I try to play DVDs or games, the
sound won't work; it will just have the same sound from whatever
channel it was on before (eg 1-5). This was caused by someone pressing
random buttons on the remote, and I can't work out how to fix it. Thanks
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
SOURCE: can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
SOURCE: Toshiba 26LV610u TV with no sound on one channel
If you have lost sound on only one station and are using cable or an antenna directly to the TV. Look in the audio settings as most likely the SAP mode is turned on. If the TV detects a SAP signal even if there is no audio this is what you will end up with.
SOURCE: Toshiba TV sound vanished
It is possible that the TV set has an SAP (secondary audio program) setting that has been turned on. To check this go in the the menu, find audio settings, usually the correct setting for this is Stereo, other setting may include Mono, Surr-Stereo, etc.
SOURCE: I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
28W93B 2563DB
Toshiba
156T9B 175T9B 213T4B 2151TB 2197DB 2512DB 2535DB 2539DB 2550TB 2563DB 256T9B 28Z27B2 2812DB 2857DB 2835DB 2873DB 2877DB 28W93B 2500TB 3357DB 573DB 2879DB T1510T8 25001TB7 32DB 32M8DB 2855DB CT9689 2939DB 40PW03B MV40PWA 32M9DB3 2893DB 32317B 2573DB 337BB 2552D 36/21P 28207B 2173DB 285T8B 2173DB 28W8DBA 28N03B 2505 238DB 439J936 3377DB 2181TB 82Z27B 28W23B 32ZP18P 42PW33P 32NW2DB 28ZH37B 32W8DB 32ZP38B 32NW7DB 32WIS 28N33B VTV1400 2987DB
536
Toshiba
2101TB 213T4B 2573DB 32ZP38
581
Toshiba
3377DB
216
Toshiba
2987DB
253
Toshiba
Toshiba
14T01B, 21TO1B, CT815, CT81500082B, CT824, CT832
746
Toshiba
TVD213B
726
Toshiba
CT90040
508
2987DB 3339DB 2877DB 322D09B 2173D6 14N21B2 14N21B2
063
536 063 271 098 117 232 530 581 130 473 088 182 064 216 253 508
