First and foremost,do you know how to operate your universal remote control?refer to it`s manual...look for that unit`s brand if it is also included to the unit that this remote control can command.if it included,look for the codes below it and try to follow the steps/methode of using this codes.example;:; 1-press the search button for 3 seconds until the led stop blinking or start to blink 2-press the unit(tv`s,dvd,ref,a/c,etc...) 3-put the 3 or 4 codes ,4- etc....
SOURCE: universal remote
try http://www.chunghop.com/en/customer.asp and download the instructions and code for your tv. you'll need WinRar to open the files, search google to download it.
SOURCE: tv remote control
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: remote to tv doesn't work
Hello
Check the remote first for its infrared emission. If it is OK, the infrared sensor inside your tV is faulty. It should be replaced with same type and number. It can be located just behind the infrared window at the front panel of your Tv. You ahve to open your TV ot access it. It will have three solder terminals, and will look somehat brownish black in colour. Will look like this.
SOURCE: Sky TV remote control code to replace my Goodmans remote control
Had the same problem for years - code is 2155
SOURCE: I bought a universal remote a phillips it didn't
Direct Code Entry
Code Search Method
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
