Jan 19, 2015 - What should I do if code E90 appears on my air bubble spa control panel? ... If alarm code E90 is displayed on the control panel, it means no ...
System Error: 010030 034c095e
Problem
Description:
This error code appears when the power supply detects a low spike
(e.g. due to a temporary loss of tension). There is nothing wrong
with the Printer.
Corrective Action: Re-boot the Printer and the error code should not appear again.
NOTE If the error code appears again, try connecting the Printer to a
different power socket.
Your Error code is 94
81. - 95. (0101xxxx) Phase 2 to 3 - Display/ Motor Control
Module. See Fault Code 106 106. (01101010) Phase 2 to 3 and 5 - Display to Motor
Control Module Communications Errors
(Phase 6 IW Also)
These faults are reported when the Display Module detects an error in
the communications between the Display Module and the Motor
Control Module.
Phase 2 to 3
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module. If the new
Motor Control Module corrects the fault, refit the
original Display Module.
Phase 5
Primary Source: Pump
Action: Measure resistance of pump. If resistance is
less than 33 ohms, replace pump.
Secondary Source: Display Module.
Tertiary Source: Motor Control Module.
Readings You May See When Unit is AC Powered Display Shows Alarm Sound Unit Status Recommended Action Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer and flashing dot 30 seconds AC powered service at 1-800-880-6788 Readings You May See When Unit is on Temporary Battery Backup Display Shows Alarm Sound Unit Status Recommended Action Flashing dot None Normal battery-only operation - Plug in to AC as soon as unit will show reading only if it possible to conserve battery senses CO Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer "Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here: http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
If this is a Kenwood, then Error 99 means the following:
• E-99:
Changer
malfunction, disc may be caught in machine or changer requires service.
Before replacing the unit try disconnecting battery for two minutes (ensure you have car anti theft code). If that does not work, then the unit must be taken apart, there is a disk stuck or a mechanical problem.
Regarding replacement, to find one you need to post details on make and model. Ebay is a good source for second hand factory replacemnts. Here a generic list. Shopping
results for cd changer kenwood About
The problem is the ribbon cable,the one connects the face to the main board,if you live in USA you can order it from pacparts.com or sony.com.
For replace it you will need to open the unit and open the face by moving manually the gears,then remove the side screws of the face and remove face,then remove the cd mech. you will see the ribbon connector.Just replaced and put everthing back togheter.
Good luck
The "Busy" code will be on when the camera trys to use a flash and waiting for its charging action. Upon completion of charging the mechanism returns a signal to the camera to fire the shutter.
That means now your camera has something wrong on the flash unit and the camera waits for some certain time frame to finally determine it cannot complete a photo-taking command.
An "ERR 99" denotes that this kind of error has not been encorded explicitly and needs investigation services.
