Question about RCA RCU600M Remote Control
I need to code a magnovox vcr into my innovage remote
Posted by giebeldee on
Anonymous
  • 2,335 Answers
The codes for a Magnavox VCR are: 021, 060, 062, 104, 106, 115, & 124.
To program your remote by entering a code, follow these steps:
  1. Turn on your VCR.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the VCR button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the VCR and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Posted on Dec 23, 2009
4helpful
MY FRIEND HAS A UNIVERSAL INNOVAGE JUMBO PANASONIC REMOTE AND NEEDS THE CODE TO PROGRAM HIS TV AND VCR AND THEY ARE BOTH PANASONIC TOO
Panasonic tv codes are 003,054,055,062,070,148,170 and 171
Panasonic VCR codes are 021,060,115,125,138,148 and 149
I need a code for my tv zenith i have a jumbo remote laxmax
Hello
Three digit remote codes for Zenith TV with Innovage Jumbo remote control are:
004 / 005 / 006 / 019 / 196 / 004 / 051 / 083 / 152 / 153 / 154 / 210 / 217
OK.
I need a code for my innovage jumbo remote. for a samsung dvd-vcr player
try this website, i specifically found the Innovage jumbo remote codes here, but if you scroll down it has several remote codes listed by manufacturer of the remote. Hope it helps!!
http://www.xdiv.com/remotes/
Dr Reed
Need code for jvc
These are the JVC codes for an Innovage Jumbo remote:
TV:
013, 054, 055, 060, 065, 067, 089
DVD:
181, 193
VCR:
009, 022, 043, 111, 123, 151, 152
5helpful
2answers
Programming the innovage remote
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Codes to program Innovage Products Jumbo Universtal Remote
Try this site;
http://www.blurtit.com/q717681.html
Good luck
Innovage Universal Remote
My code light stays on...will not accept and buttons...any ideas
13helpful
5answers
Admiral tv/vcr, innovage jumbo remote
YOU CAN USE EMERSON CODES FOR YOUR ADMIRAL TV AND TV / VCR COMBOS, MY COMCAST REMOTE ACCEPTED 11911. SOME REMOTES NEED FIVE NUMBERS AND MY ADMIRAL ONLY HAS THREE. SO I USED AN EMERSON CODE AND IT WORKED MOST OF THE BELLS, NOT ALL WHISTLES WORKED BUT I DIDN'T HAVE TO GET UP TO TURN IT ON, CHANGE THE CHANNEL OR THE VOLUME. MY KIDS WON'T DO IT ANY MORE!!
GOOD LUCK!!!!!
3answers
RCA RCU600M Remote Control Logo
Top RCA Televison & Video Experts
 Francisco Mauricio...
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
