Sine function calculates a completely different number For example, sin(1) = -.84~~~ right? On my calculator it states that sin(1)=.015
It depends on the unit of measurement. The sine of one radian is about 0.84. The sine of one degree is about 0.017. The sine of one grad is about 0.015. From your numbers it looks like your calculator is set to grads when you want it to be in radians (and are you sure you want a negative number for the sine of one?).
Press the DRG key to cycle through the angular modes. One of the annunciators at the top of the display will light to indicate the current mode.
SOURCE: FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
SOURCE: Sharp EL531WH Calculator
I had the same problem... all you have to do is reset the calculator:
Type:
2ndF
ALPHA
It'll give you a choice Mem (0) or Reset (1)... press 1
Then it'll say Reset? (0)... press 0
And your calculator should be as good as new!
SOURCE: Replacing inking roller/ribbon?
i had a problem with this as well and found a user manual online. I thought the whole thing came out but it doesn't. If you pull up on the little red thing on right and then the black one on the right you have it. Imagine that! That's all that you change. Then just put some new ones in and your good to go.
SOURCE: Half-life exponential problem. Can't get the same answer as example
Here is how you enter it.
[+/-]0.693/8x4[2ndF][e^x][=] result is 0.7071588193 or as you wrote 0.7071
some calculators show an error message if you enter the [+/-] (the negative of a number before the number itself).
In that case enter 0.693 then press [+/-]. the calculator should put a small - sign before the 0.
You can try
0.693[+/-][x]4[/]8[2ndF][e^x][=]
Hope it clarifies things.
SOURCE: CALCULATOR MIS-FUNCTION .
unfortunately the printer is out of time or the selector pawls got bent. would be cheaper to buy a new one than fix this.
