Question about Integra Audio Players & Recorders
Front speakers don't work on Integra AV receiver DTR-40.1
5 Related Answers
Anonymous
  • 92 Answers
SOURCE: no output to subwoofer per-amp
you may have to go into the onscreen menu and enable it,that shuld work
Posted on May 20, 2009
Anonymous
  • 9 Answers
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
Anonymous
  • 4 Answers
SOURCE: THE SPEAKERS FRONT LEFT AND RIGHT IS NOT WORKING ON DTS and 5.1
Do you have the manual if not go here.
http://www.hammerwall.com/Manuals/Pioneer/Description/VSX-D608/Pioneer%20Home%20AV%20Receiver/L0020200/
Posted on Aug 21, 2009
Peter Bradley
  • 57 Answers
SOURCE: my left rear speaker has no sound. All others
Swap your left and right rear speaker over. If you still get no sound from the right speaker connected to the left speaker connection on the receiver, then you have a fault on the receiver output. Check your manual first to see if any setting switch off the rear speaker before taking the unit for repair or replace
Posted on Nov 26, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have a Integra receiver
NO sound at all? That would be odd as its internal FM receiver is independent of any user connections. I'd work on getting FM to work first, then move on to more complex issues.
The manual is here:
http://www.retrevo.com/support/Integra-DTR-6.6-Receivers-manual/id/550ag000/t/2/
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Posted on Dec 26, 2010
My integra av receiver model no DTR-70.1 amplifier displays but no sound what could be the problem?
http://www.integrahometheater.com/faqs.php Check the connections and try a master reset?
Perform a master reset. To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode.
Jul 03, 2018 | Integra Audio Players & Recorders
I have an Integra DTR 20.3. Recently, I have been getting no sound from the speakers after removing the headphones from the headphone jack. Any ideas?
Usually the headphone jack has a contact that's "made" by the 'ring' section of the jack when you push in the plug, which bypasses the speaker circuit (that's what automatically silences the speakers when you plug in the headphones when there are no switches to turn the speakers on/off manually)... if the 'ring' strip got bent somehow so it's pressing against that contact all the time, it won't let the speakers' circuit come out of bypass. Look inside the jack with a flashlight... the sideways Vs that touch the 'ring' sections of the stereo headphone plug should be about in the middle of the opening... if they're pushed over too far it may require disassembly to bend them back to the proper position.
Mar 08, 2015 | Integra Dtr-20.3 THX Select2 Plus AV...
I am not getting any audio (sound) out of my Integra DTR 4.6. Any suggestions?
Does the vu meter show anything(bars moving up and down when audio is present?If so you may have a blown fuse or bad IC in the amplifier section causing the problem. If there is no indication of audio on the front panel it would be a Microprocessor problem
Oct 15, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
Only one speaker working
pls. identify w/c channel is working then try switching the speakers, check your rca cords from your source player, try to switch them. th
May 05, 2013 | Integra DTR-9.1 7.1 Channels Receiver
I have a Integra receiver model number DTR 66 and I have no sound. it appears to have everything connected and should be working. I would like to know how to reset the receiver or what steps do I need to...
The manual is here:
Dec 26, 2010 | Audio Players & Recorders
Front speakers work but surround sound speakers do not what can i do?
surround speakers work only when you put 5.1 ch recorded dvd in it
Jun 02, 2010 | Integra DTR-5.1 Receiver
Jun 30, 2009 | Integra DTR-5.2 Receiver
No output to subwoofer per-amp
May 11, 2009 | Integra DTR-8.3 Receiver
Top Integra Audio Players & Recorders Experts
Bill DiBrino
Level 1 Expert
Naheed Mir
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
