Question about Motorola CP200 Two Way Radio
Is Radius cp200 compatable with rdu2080d
How can I make my Radius cp200 communicate with my rdu2080d?
eradiostore
  • Motorola Master
  • 1,658 Answers
If your model number starts with AAH50R... the answer is yes. The CP200 could be programmed to match your RDU.
Posted on Dec 17, 2015
1 Related Answer
eradiostore
eradiostore
  • 1658 Answers
SOURCE: compatibility
If your CP200 has a model number beginning with AAH50R it can be programmed to match the RDU2080d. If your CP200 model number begins with AAH50K, then the answer is no.
The letter R in the model number indicates it is UHF, and on the RDU2080d, the letter U in the model name indicates it is UHF. Both of these radios are programmable, and could be reprogrammed to match one another, if both UHF.
Best regards.
Posted on Sep 21, 2012
Why motorola radius cp200 flashes red while charging?
Typically when the charger flashes red you have one of the following conditions:
1) The battery is simply too low to charge. Leave it on the charger for a few hours to see if it resolves. If it is a new battery return the battery for a replacement.
2) Your battery is not making good connection. Clean the battery and charger contacts with a pencil eraser. Check your contacts in the charge itself to make certain one isn't damaged or broken.
3) Your battery has an internal short. Test the battery on another charger to see if you get the same result. If so, replace the battery. 4) If you have a charger problem, the best test is to try another battery in the charger. Reminder: be certain the insert is turned the correct direction for the battery you are using.
Best regards.
Apr 30, 2014 | Motorola Mint Radius Cp200 Uhf 4ch Radio
Cp200
can you increase the volume? did you try the morse code button beep beep? are both units on? 10-4 big daddy truck nuts Over and Out
Mar 22, 2014 | Radio Communications
How can I program my rdu2080d to communicate with my cp200
Both radios require appropriate programming software and cables. Your CP200 would need to be a UHF model in order to match the CP200. Your best option would be visit your local dealer or contact an online repair center for help in programming.
Jan 30, 2014 | Motorola CP200 Two Way Radio
HEllo, I have a Motorola Radius CP200. When I
If the sound is continuous, like a long tone humming, it is possible you are on a channel which is not programmed. Try changing your channel knob to a different channel and see if the sound changes.
If the sound is not continous, and only happens upon pressing a button, we are not certain what you are experiencing without seeing the radio first hand.
If it were the battery you would get a low battery beep and then the radio would shut itself down. This can happen from a bad battery or a low battery. If this were the situation, you should check your charger and be certain the light comes on and stays on when the radio is placed on the charger. (Note: your radio should always be turned off when on the charger.) A quick test would be to swap the battery with a known good radio and see if you have the same problem. If so, you know it is not a battery or charging problem.
If none of these items help, send or bring the radio to a Motorola repair shop for a quick analysis.
Best regards.
Aug 21, 2013 | Motorola CP200 Two Way Radio
Motorola Radius CP200 flashing yellow when charged
The battery is no longer taking a charge properly and needs to be replaced.
Feb 12, 2013 | Motorola Mint Radius Cp200 Uhf 4ch Radio
ONE OF MY CP200 RADIOS HAS A STEADY SQUELCH SOUND ON ALL 4 CHANNELS, HOW CAN I FIX THIS?
One possible problem is a bad battery. Try swapping batteries with a known good unit and see if the problem is solved. If it is not the battery, then your radio is likely in need of repair.
Best regards.
Nov 09, 2012 | Motorola Mint Radius Cp200 Uhf 4ch Radio
Compatibility
Best regards.
Sep 20, 2012 | Motorola CP200 Two Way Radio
My Motorola Radius CP200 has lost all channels that was set by dealer is there a way to reset back to factory settings?
It is seldom a CP200 loses frequencies/PL code settings. It is more likely the radio has a bad battery or another issue. The only way to reprogram the radio is by taking it back to a Motorola dealer, as they are all dealer programmable only. Sorry.
Best regards.
Dec 18, 2011 | Radio Communications
Motorola CP200  Two Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
