Model #312158 beeps for unknown reason.
SOURCE: Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
SOURCE: Frigidaire Range - Model #PLGFMZ98GC - Beeping
Turn or unplug from wall, let sit for five minutes then plug back in. If unit is ok and then in a day or two does it agin or starts beeping agin, then replace clock control. Common problem with this unit after about two years of use. Usually caused by defective touch pad or "endless loop" in programing code of micro-processor. One other problem, is if you had just used the self cleaning mode, then you may have a oven lock problem, doubtful though, clock control is majority of prob on these units.
SOURCE: my microwave beeps for no reason even when not in
There is a reason. Try to reprogram the unit. Start w/menu: date, time simple stuff. This should take care of it.
SOURCE: My folks (elderly) have a
I will advice you try to reset the device, once the device is reset, the problem should be fix, just reset the device to fix the problem.
Take care.
