Question about GE PGS968SEPSS Profile 30" Slide In Gas Ranin Stainless Steel with
He states that uneven flame is normal. Service tech was here spoke with GE tech said this is so pot handle won't get hot and another one said it is so if the stove is next to a wall it won't catch fire. This can't be correct. Everything is clean and aligned. Half my food burns while the other half doesn't cook
Are the burners uniform around top? Pictures show that there is a slot on one side. The tech is probably right.. You are not the only person complaining about this. Call back and see if there is a different burner that will fit you stove.
Posted on Dec 20, 2017
SOURCE: Burners only work half way
Remove the burner knobs, inside of each shaft is a straight slot screw adjustment, use a flshlight to see it. Sears has screwdrivers this small.While holding the shaft with a pair of pliers turn the screw in the shaft, it will be hard to turn, this is normal.
Continue doing this until you obtain the desired flame setting.
Posted on Apr 27, 2008
SOURCE: uneven flame on GE profile
Hi, That is not that hard to fix and you can easily buy the parts yourself online...
First check the way the burner is assembled.... compare it to the other burners... seems as though it may not be put to gether properly....
However if this was a defect from new there may be a flaw or something stuck inside of it...
Probably will not get warrranty on it now... but you could try....
Anyway...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Jan 02, 2011
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Apr 06, 2014 | GE 30 in. Profile JP350 Electric Cooktop
Aug 17, 2017 | GE 30 in. Profile JP989 Electric Cooktop
Aug 18, 2012 | GE 30" Free Standing Electric Range
May 17, 2011 | Jenn-Air JGD8130 Gas Cooktop
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
Jul 09, 2008 | Cooktops
Jun 26, 2008 | Cooktops
Oct 11, 2007 | GE 30 in. JGP337 Gas Cooktop
Sep 24, 2007 | GE 30 in. Profile JP938 Electric Cooktop
317 people viewed this question
