Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Wont Drain
My machine started making a clicking/metronome type of sound toward the end of the cycle when it was draining the wash water. I tried to just put it on the drain and rinse cycle and I get the same clicking sound coming from the upper left hand side of the machine. Does any one know what part my be causing the touble?
thanks
Posted by cpugsie on
  • Anonymous Nov 01, 2007
    My washer makes the same clicking sound when the cycle begins and intermittently throughout the beginning of the cycle. It only does it when it is in the slow spin.
  • yogurt Nov 11, 2007
    I have it only when the drain motor is supposed to run any ideas??
Anonymous
    Scholar:
  • 146 Answers
Sounds like a relay on the board. Have you tried to reset the machine by switching it off at the wall and leaving it for about 20 seconds before switching on again?
Posted on Nov 06, 2007
Why is my eiflw55hiwo electrolux front load washer not properly draining the water at the end of the wash cycle?
hmm sounds like as if any water sensors arent working as they should inside the washing machine's basket or the diagnostic board isnt getting the right info from its sensors in the washing machine's wash tub
Aug 22, 2017 | Electrolux Washing Machines
My nanussi washing machine won't fill with water, when i put in onto a cycle it sounds like water is filling then it clicks off 1min later. Drier seems to working fine.
HI lisa
Have you moved your machine recently ? It sounds like it could be the drain outlet hose that is too low and the water is syphoning away If your machine dose not fill within a preset time it will stop. Is there any error codes or flashing lights.If water is going into the machine and the tub is not filling check that the end of the drain outlet hose is no lower than the centre of the door.
May 25, 2016 | Washing Machines
Why is my whirlpool auto load sensing washing machine spraying water while in final spinning cycle?
you could have a bad temperture sensor bad are water valve but first check an make sure the washer drain alway check your drain hose for clog are lint are trash in pump an last you could have a bad timer if you dont know how to check these call a applince service for repair ok
Dec 13, 2017 | Washing Machines
Simpson swf85561 wont drain, spin or wash goes to end cycle
It sounds like your outlet is clogged. Unplug the Washer first. You need to take off the back, there is a plastic piece attached to the hose where the water comes out. It may look like an enclosed bowl. Items that get sucked in, socks, scarves, etc... tend to get caught into this. If it is supposed to be clear, but it isn't, then there is something stuck in there. You must pull it apart and remove the laundered item.
A way to avoid this happening in the future, if this is the cause, is to put small washable items in the center of the load. Do not overload the washer.
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Feb 22, 2014 | Simpson Washing Machines
Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Mar 22, 2010 | Kenmore 43142 Front Load Washer
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
Set it toward the end of any cycle - it will sense the water level and pump it out before moving on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Clicking Sound between agitation and drain cycle
Is it a front loading or top loading washing machine?
Oct 08, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
107 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
