SOURCE: Brother ML-500 Typewriter Typing the wrong characters
The printwheel is not in correctly. the printwheel has a bent spoke or the printwheel homing sensor needs cleaning. Lawrence
SOURCE: Brother EM530 Typing Wrong Letters
Hi there. Take out the printwheel and see if any of the spokes are bent. That would cause wrong letters. . Also if the print solenoid(piston) does not go in and out freely. Lawrence
SOURCE: ML 100 Brother - Standard
If the characters are showing up different than the ones you pushed then your wheel is probably bent. First, open the clear cover on your ml100. Second there is a black lever that you pull towards you. Next, you pull the wheel out and if any of the arms on it are bent than straighten them out, and make sure none of the arms are over lapping. Next, return the wheel, push the black lever back into place, close the clear cover and then hold down the code button and press the reset key (the "q" key). If that does not work then you need a new wheel. This is what just worked for me, I hope it helps.
SOURCE: Change margin
Do you see the lmar and rmar above the number keys printed on the cover? Move the carriage to where you want to set the left margin Then hold down the ALT key and depress the corresponding number key under the lmar symbol. Repeat for the right margin.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
SOURCE: my brothers ml-100 is typing the wrong letters,
Replace your brother CASSETTE DAISY WHEEL w/ letters. this solve my problem by only buying a new one.
