Question about Konica Minolta Magicolor 4690MF Multifunction Laser Printer
Konica minolta magicolor 4690 mf won't print after changing network setting
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
I would recheck the network setting first why where they changed???
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 25, 2016
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
Posted on Aug 23, 2007
Anonymous
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
Dan Hudson
  • 118 Answers
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Posted on Nov 18, 2008
Anonymous
  • 3 Answers
SOURCE: Printer leaves two white lines when it prints.
I had a similar problem with my 2430DL only with one fairly prominent white line instead of two. I read troubleshooting tips in manual for this problem and first suggestion was to wipe laser lens clean with a soft cloth. I did this and no more white line! If you do not have your manual please email me and I can forward you PDF manual. [email protected]
Posted on Nov 23, 2009
Anonymous
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
Not installed toner check Y error message
replace the yellow toner container with OEM NOT THIRD PARTY
Jan 27, 2016 | Konica Minolta Magicolor 4690 MF Laser...
as before check the network setting correct ip address cabling usb?
Jan 30, 2014 | Konica Minolta Magicolor 4690MF...
Konica 4690 mf switchback jam
check the sensor might be dirty
Dec 20, 2013 | Konica Minolta Magicolor 4690MF...
Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
85 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
