What dose the seagate proagent 500gb do for your computer dose it make it faster
SOURCE: Seagate FreeAgent Pro - 500GB No detection need drivers
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive should be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
Also if you still need driver:
This is the best way to download the drivers of all your devices which are connected to the system for free.
You can download the Driver Magician from this link :
http://www.toggle.com/lv/group/view/kl34858/Driver_Magician.htm
Download the reg key from this link :
http://public.box.net/paul123
then doule click & select ok.
Run the program and select update drivers, it will list the list of pdated drivers.
Select the drivers and select download drivers.
If it does not download just select the driver you need and at the bottom you would see a link,
Just copy that link and download from your browser or download manager, I use orbit downloader.
Good Luck.
Live, Love, Laugh.
SOURCE: Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
SOURCE: I have a Seagate Free Agent Pro GB HD. Recently
Hi and Welcome to Fixya,
Here is the download site from Seagate http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Please check that link and then download the driver for your device.
SOURCE: I have purchased a Seagate free agent Goflex 500gb
For a MAC to use an external Hard drive, the hard drive has to be formatted FAT32 file system. That is the only file system MAC sees.
SOURCE: My desktop crashed. I lost
External hard drives are plug and play, the drivers are build into windows.
IF the hard drive was connected when your computed crashed, and the hard drive was in use, it may have damaged it.
If it does not automatically connect to other PC's looks like it has been damaged
