Question about Home Fencing
Bin standing for a year carb needed clean and unblocking sorted that but still no fuel getting o engine tipped petrol down spark plug it fired
SOURCE: merc 190e fuel injection problem
If the fuel gets to the distributor but no fuel comes out of the distributor if the airflow disk pushed into the air/fuel mixure body, i suggest you check the electro-hydralic-actuator
Its the black box (picture thanks to elproboscis from ebay america) as it controles the flow to the pluger body inside the centre of the distributor and goes from the plunger direct to the 4 outlines.
Posted on Aug 18, 2008
SOURCE: 1997 cb500 won't start
finally sorted when I replaced both plugs. I've never come across one failing instantly before in 30 years of motorcycling (maybe that's because I ride old bm's!)
Posted on Feb 04, 2009
SOURCE: engine will not start,carbs cleaned, but will not fire, no petrol
Check the carb diaphrams for any tears/pinholes? (They are on the top of the carbs) Have you reconnected the breather from the tank? Is fuel getting past fuel tap? Sometimes the vent in the fuel cap can get blocked with crud and create a vacuum which stops fuel flowing.
Posted on Mar 15, 2009
SOURCE: Engine has no spark. 3HP Briggs and Stratton +
If you get a shock from the HT lead then you do have spark!!
Connect spark plug with it removed and shorted to see if there is spark, if not use screw driver to hold away from steel (1/4") with end inserted in HT lead,If good spark / faulty spark plug.
Check for
Spark
Fuel to spark plug
No air leaks.
Posted on Mar 16, 2010
SOURCE: petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Posted on Sep 12, 2011
Mar 08, 2014 | ATVs
May 26, 2013 | ATVs
'm sorry but
you have this posted in the wrong product category. Please re-post
the question in the proper category This is the car and truck problem
category
Jun 24, 2012 | Cars & Trucks
Mar 06, 2011 | 2005 Honda XR 400 Motard
Jan 09, 2011 | Razor Dirt Quad Bike
Dec 01, 2010 | Yamaha G5 Motorcycles
Jan 13, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Sep 16, 2009 | Garden
Aug 16, 2009 | 1972 Suzuki T 350
May 17, 2009 | 1986 Yamaha RD 350
Apr 23, 2017 | Home Fencing
299 people viewed this question
