Question about Lenovo ThinkPad Computers & Internet
Clumping palms are dying
The fronds brown off then eventually the palm dies from the top down. I cannot detect anything like mould or aphids anywhere on the plants
Posted by Veronie Hollands on
Russ Hill
  • Lenovo Master
  • 4,057 Answers
Check you soil ph sometimes the soil Ph can change. and can cause this. also try some plant food in water. out side plants sometimes need some food over the cold months. also if it gets to cold for to long it can kill the plant off.
Posted on Jan 30, 2014
Testimonial: "Thanks for your quick response. Amazing. We don't really get much cold weather here. We are in Central Western Q'ld."
  •  Russ Hill
    Russ Hill Jan 31, 2014
    yeah thats whats a matter with your plant they get used to the normal temp for times of year. you can put some netting around the roots to keep them warmer. even an old blanket can help plenty of water and food and make sure the soil ph dont change and it should be fine.
1helpful
Why can I pull out brown fronds by my hands on my sago palm's trunk?
Usually once every year or two, Sago Palms bottom frond will die off in order to produce new ones that shoot out the top. Once they die you can pull them out with your hand because the fibers that attach them are also dead.
1helpful
Color lines on palm pilot screen
Have you tried to do a factory reset?Chances are the screen is old and dying. What's the damage too the phone?Has it been dropped, water contact? Anything like that at all. Those are all things to factor in as to why most phones malfunction
My palm tree appears to have died following a recent cold spell. the leaves have turned brown and are falling off. is there anything i can do to save the tree?
Unfortunately,no not at this point.You will have to replace them.Next year use 1x2 stakes and build a frame to fit around and over the trees.Staple CLEAR pe tarp and you have an instant temporary green house.A roll of 100yards by 20 feet at Lowe`s is about 80usd,and can be reused.
May 13, 2011 • Garden
Hi there, we have recently moved house, the palm tree (according to the previous owners has been there over 16 years planted by themselves). The tree has been shedding its leaves over the winter months,...
Hello Eileen, W/D here.
Palms will reabsorb some of their nutrients when fronds are shed, even over winter. If possible, you should let the ugly fronds go, and allow the trunk to take back what's stored in the frond stems. When they become brown, or less green, or droop, they can be pruned. This is usually found with the lower fronds. If upper fronds exhibit these symptoms, it is usually from the effects of winter, but the same rules apply, except that you can trim partial fronds to get rid of the brown leaves.
The acid test for a palm is, if there are shoots in the middle of the canopy protruding, to pull on them firmly, but not aggressively. If the shoots pull out easily, the palm is probably dead. Some winters are more brutal than others, and palms take the worst of them. We double-cover our palms, and place lights inside of the covering that we make, and the larger ones have made it over winter now for about 5 years. I have used incandescent Christmas lights wrapped around the trunk and hung in the canopies, then covered and it worked well too. One friend slaved his Christmas lights to his pool pump control panel, only to lose his palms. Seems that he was using LED lights, which put out no heat. Queen palms have died in droves this, and last year, as have unprotected Robellinis. Washingtonians and Pindos have fared better. If you live in a coastal zone, you still need to cover and keep your palms warm through the worst of winter. We have used fitted sheets on the smaller canopies to contain the fronds, then covered that with plastic tarps, weighted down on the sides to form a mini greenhouse, and it works pretty well, but it's inconvenient. With spring here, there will be a lot of new outdoor umbrellas purchased, and the old ones will be pitched. We already have picked one up from a neighbor, and will erect it over one of the palms, then cover it as described. The thinking here that it should be much easier (and quicker) to protect the palms via this method.
As for the fungus noted, try light applications of a fungicide, but check first with a local nurseryman to see what works best in your area.
Hope that this is of some help.
Best regards, (and please rate this solution), --W/D--
Palm Zire to itouch
Those two devices are not compatible to one another. You may get it to work by exporting the Palm desktop data into a CSV file and importing it into the program you use to sync the Itouch with.
2answers
Palm IIIx Screens Die
It is possible that screen connector got loose. My initial intermitent problem was that PDA wouldn't turn on properly, the screen would flicker and/or show grey area. On my palm IIIx I did remove the back cover and pushed the connector all the way in the slot and now it works just fine.
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
Steve Sweetleaf
Steve Sweetleaf
Michael Thomas
Michael Thomas
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
