Question about Adobe Photoshop CS4 Extended Full Version Volume License for PC
Fix AppHangB1 A few days ago I came across this problem, and I'm not sure what's causing it. I tried to open Photoshop, and it just got stuck in 'Initializing menus'. When I clicked to see what the problem was, the error I was given was ApphangB1. I thought something weird might have happened, so I did a system restore to the 16th of January. When my computer booted back up, all seemed to be fine. Photoshop opened right away. The next day I needed Photoshop again, opened it, and got the exact same issue. So I just restarted my computer, and I was able to open Photoshop. I closed it to test to see if it would open again. Encountered the same issue. Photoshop will work when I restart my computer, but obviously, it's ridiculous to have to restart my computer every single time I want to use Photoshop. I've never had this issue before, and before then, Photoshop was always working just fine. Does anyone have any ideas on how to fix this? I'd be ever so grateful if someone could give me some ideas on what I can do to get this resolved.
5 Related Answers
clark_styx
clark styx valencia
  • 282 Answers
SOURCE: Photoshop 8.0 (part of Creative Suite Premium)
this might help
Posted on Aug 27, 2008
Anonymous
  • 51 Answers
SOURCE: Every time I try to open a document using adobe
reinstall it i have the same problem after reinsatlling it work fine and do check ur system for viruses
Posted on May 19, 2009
SOURCE: adobe reader error message
It is possible that somewhere along the line adobe reader became conflicted with an update from something else ect.
First thing you should try is uninstalling adobe reader completely in add/remove programs. Then Install the latest version of adobe reader.
This should put an end to the error messages and restore functionality to normal.
Post back if you need any further help.Thank you for choosing Fixya!
Posted on May 27, 2009
Anonymous
  • 18 Answers
SOURCE: tool palette freezes
There are a couple of possibilities. 1. Confirm the image is in RGB color mode, sometimes CMYK or Index color will lock tools (Image->Mode->RGB) 2. Sometimes part of the image is selected, even though you may not see it. Try using ctrl+d to make sure you have de-selected all of the canvas. Good Luck!
Posted on Aug 21, 2009
AldRezaine
Aldrine Manalo
  • 995 Answers
SOURCE: Won't burn to DVD
Reinstall your ADOBE software. First, uninstall it and restart your computer to clean up the left over files of the software. Once done, install a fresh copy of your ADOBE. :-) Don't forget to rate me..Thanks..
Posted on Nov 07, 2009
Photoshop15 .psd file crashes on startup
I suggest the following which worked for me.
Open the Photoshop program folder and open the Plugins folder. Move all the plugins to a separate empty folder on your desktop. Be sure there are no files in the Plugins folder
Next restart Photoshop 2015. If it opens correctly replace the plugins, one by one, into the Photoshop Plugins folder and restart Photoshop 2015 after each individual replacement. When Photoshop 2015 stops starting correctly you have found the offending plugin(s).
After doing the above I found two plugins that caused my problem. Downloading updates for the offending programs that were created to solve Photoshop 2015 plugin problems and installing them solved the issues for me so I can use those plugins again.
Also I found this program Photoshop Fix Toolbox https://www.fixtoolbox.com/photoshopfix.html
Feb 16, 2016 | Adobe PhotoShop Computers & Internet
When i am starting this game it will not open, so i open task manager & that will show as not responding & the problem is AppHangB1. What is the solution for this?
The issue is typically due to too many windows processes being open at the same time. Make sure you close all open windows and file folders before launching the game. Also installing all the latest windows updates may help. AppHangB1 is windows trying to unfreeze itself. So if all applications are closed the game should run no problem.
Jan 11, 2014 | Activision SpiderMan Web of Shadows
My cd/dvd port slot keeps getting stuck.
Lubricate it. Otherwise change it for a brand new unit for $15-25 only. Now they are cheap as dirt. & it will last for 5 more years.
Sep 19, 2009 | Tascam (CDRW900)
Cannot select any tool other than the "Hand Tool"
sir how 2 slove it.......................................
Apr 04, 2009 | Adobe Computers & Internet
Opening RAW images from Nikon D70 on photoshop
A Photoshop Raw file is a Photoshop PSD file without a header. The header
information must be entered when the file is imported into Photoshop. The
raw format is used import and export bitmap data using a very simple,
uncompressed binary format.
Nov 30, 2008 | Nikon D70s Digital Camera
Photoshop cs3 error
Are you trying to open a download?
Jul 17, 2008 | Adobe Computers & Internet
Loosing pressure sensitivity
I was trying also, didn't work at all, and I'm going to try to close and open Adobe Photoshop CS2. But I need it to work on a few adoptables! I need it NOW!
Nov 29, 2007 | Wacom (PTZ930AC) Graphic Tablet
Frozen?
Make sure hold/lock is disengaged
Then reset - check you manual, because BenQ no longer carries the manual
Oct 22, 2007 | BenQ Joybee 210 MP3 Player
Adobe Photoshop CS4 Extended Full Version Volume License for PC  Logo
466 people viewed this question
Top Adobe Computers & Internet Experts
Jane
Level 1 Expert
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
