Cars & Trucks Logo
a
apry leib Posted on Jan 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Key wont come out ignition
Key gets stuck in ignition when I turn off engine. It is like Russian Roulet everytime I go to take the key out...what is causing this? I was told by a mechanic to try "lifting" the gear shift and then take the key out but that doesn't seem to impact whether or not the key will decide to come out! Please help...this is a 2003 Ford Windstar
jason okeefe
Level 2:
Habit-Forming:
New Friend:
  • Expert 93 Answers
  • Posted on Mar 06, 2015
 jason okeefe
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
93
Questions
83
Helped
15298
Points
189
Under steeringh wheel you will se a removable plastic circle or oval remove that and stick something long enough to reach button and remove key
5 Related Answers
Anonymous
  • Posted on Oct 16, 2008
SOURCE: key gets stuck in ignition
My daughter drives a Suzuki, my solution to her is: while the gear shift lever is in park, lightly put pressure on the gear shift lever, through the park position and while pressing the gear shift towards park light rock left to right while trying to remove the key.
The interlock between the transmission and the ignition switch needs to be adjusted/ repaired or replaced.
Anonymous
  • 426 Answers
  • Posted on Nov 12, 2008
SOURCE: how to get key out that is stuck in ignition
Remove steering column shroud(cover)and tap ignition barrel with small hammer while twisting key backwards and forwards,also turn steering wheel backwards and forwards sometimes this is enough to release key as the locking pins in barrel and the steering lock pin do sometimes jam.You will have to remove steering column shroud to replace ignition barrel if tapping/hitting it doesnt work anyway so its not a wasted effort.Good luck,let me know how it works out
Anonymous
  • 5 Answers
  • Posted on Dec 14, 2008
SOURCE: Key wont turn to Ignition point
you need to buy a new ignition tumbler
Anonymous
  • 65 Answers
  • Posted on Feb 26, 2009
SOURCE: how come the 1998 ford windstar 4 speed trans wont shift out of 2
HI !!! there usully one problem w/ this when thoesnt shfti right from firs to the second also takes more time is the Solenoid Pack in Rey. have computer tested and it wil tell you which has to be changr all this work inside the trnsmsion
Anonymous
  • Posted on Nov 01, 2009
SOURCE: Cant open bonnet of Ford Focus x reg grill operated key lock wont turn
Stuck lock, bonnet won’t open ,,,
You do not need to drill holes in the grill or pay ford £200+
DIY..How?
Look into the grill at the top you will find the bottom of 6 plastic revscrews, 4 you get two via the grill slots use a chisel and cut them off, Then one either end of the grill. Place the chisel between two plastic layers, gently lift , check and cut, one each end.
With a wiggle that’s the top loose, There are two clips holding the bottom in place Put your fingers through the bottom slot in the grill, push down clip and greatly pull the grill, do both sides, It won’t come right out but your aim to loosen it., The lock is held in place in a sleeve with a plastic clips each side, you have push the barrel with a suitable item, this is to push it out of the sleeve and out of its housing, It may need a tap!!
Gently wiggle and pull the grill off
Lock
The lock is a ‘lock barrel along a shaft to a white plastic coupling’ this fits in to the ‘bonnet lock’
The security is at the coupling to bonnet lock in the form of a cross shaped plastic key
The key is fitted and held in place in the coupling, and when installed it’s fitted in to the lock, and once it’s in the lock part it will not come out, so therefore any jolt, pull, movement dislodges the plastic key from the coupling side and due to its design it will not slot back in so the lock barrel just rotates
To open you have to apply pressure on the shaft towards the left and into the coupling and turn the key in the lock barrel at the same time in a aim to get the coupling to catch the plastic key (take a few minutes) but it opens in the end if this is the fault, (alternatively remove the two bolts that hold the bonnet catch to the bonnet)
Once bonnet open remove the bonnet lock mechanism, then with draw the lock barrel, shaft, coupling, By looking in side you will understand regarding the cross key
Anyway you need to remove one of the catches from the side of the plastic key This way it will fit back in to coupling.
Reassemble
This is a brief description But the cost to me was 45 minutes, £2 for a pack of plastic rivets / screws, and I cached my bumper with the chisel £5 for a touch up stick Total £7. Well worth the time and effort
Shuts off engine the key will not come out the ignition but the accys is on
didnt specify vehicle -generic answer--check battery terminals certain gm wont release key if battery dead or connection lost ,,re try putting in park if not in park correctly same no key removal --the following links are other ways to remove key as well
How to get your key out of the ignition if it gets stuck How to Fix an Ignition Key That Doesn Turn
3answers
Remove ignition key
2 u key 2?
key broken off
key wont turn
shifter stuck in park?
which, or?
2010 corolla key stuck in ignition
It can be faulty ignition lock cylinder.I suggest to wiggle the steering wheel a bit and see if the key gets released out.If that is not helping then first turn steering wheel to right and try removing the key,or next turn steering wheel to left and see if you can remove the key.
Spray wd-40 in the ignition key hole and let it remain there for few minutes,after that once again try to remove the key and see if that helps.
But if that is not helping then ignition lock cylinder has to be removed out and key has to be manually removed.
For more troubleshooting on these types of issues,i suggest you to refer the help links mentioned below.Its the accurate solutions mentioned in it.that will help you to narrow the problem:-----
Click the link below:------
1999 Toyota Camry: Key Will Not Come Out Of Ignition?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-key-will-not-come-out.html
2001 Toyota Tacoma: Ignition Locked?
http://technoanswers.blogspot.in/2012/04/2001-toyota-tacoma-ignition-locked.html
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
Car will not turn the ignition to start?
http://technoanswers.blogspot.com/2012/01/car-will-not-turn-ignition-to-start.html
Ignition Key OFF but engine still running?
http://howtobyme.blogspot.in/2012/03/ignition-key-off-but-engine-still.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html-----------
Ignition locked up on Mercury Villager?
http://technoanswers.blogspot.in/2012/01/ignition-locked-up-on-mercury-villager.html-------------
Key won't turn in the ignition on Toyota land cruiser?
http://technoanswers.blogspot.in/2012/02/key-wont-turn-in-ignition-on-toyota.html
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to Replace Ignition Switch on Chevrolet Caprice Classic?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Problem Troubleshooting
http://whoisbyme.blogspot.in/2012/07/ignition-problem-troubleshooting.html
------------------These will help.Thanks.
1helpful
2006 Ion 2, Key is stuck in the ignition and wont move.
get a new ignition lock cylinder. they usually have simple instructions with them on how to replace
3helpful
2answers
Key wont turn enough to start. Key get stuck
call a locksmith they should be able to help and most likely fix/ tell you the problem
and is your stearing wheel locked meaning will it turn?
2003 Trailblazer- no power after key stuck in ignition
Sounds like an antitheft problem I would start with the antitheft system. Usually when you only have one key all keys have to be programmed together even the original. When you have more than one it is easy to program additional keys.
Wont start right away
bad solenoid / winter kills solenoids and there right beside the exaust the hot and cold wears them out real real fast.change the solenoid and it should be back to normal.and sounds like you need a new ignition key switch.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
