Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Connect mac to Konica Minolta bizhub 350 - Konica Minolta bizhub 350 All-In-One Laser Printer
Karteg
    Problem Solver:
  • 6 Answers
Recently reinstalled the computer and also needed drivers. I searched for a long time until I found https://bestresearchpaper.com/ and did not order from them a detailed essay-instruction about Minolta and how to correctly install / store drivers https://bestresearchpaper.com/
Posted on Jul 02, 2020
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Posted on May 03, 2016
5 Related Answers
Anonymous
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
steven brickhouse
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
Anonymous
  • 214 Answers
SOURCE: Konica Minolta bizhub 350 Error c0500
did you do a trouble reset ?
Posted on May 11, 2008
herminio_hal
Herminio Halili, Jr.
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Posted on Jul 09, 2009
xeerie
Zaheer Ahmed
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
I would like a list of error codes for the Konica Minolta bizhub 350
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C350
Apr 14, 2015 | Konica Minolta bizhub 350 All-In-One Laser...
Mac address for bizhub 161f
are the print driver installed properly was a ip address given to the machine
try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 07, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Cual es el firmaware
firmware is only available to Konica Minolta Dealerships and KMBS through a secure web site so it will require a service tech Konica Minolta likes to protect there copier software
Feb 16, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Error C11A3 Konica Minolta BH 350
solution for error code c11a3 konica minolta bizhub 350 machine
Jul 21, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c350 installer for mac
You have to have a fiery unit (external controler) to use the C350 With a Mac because the c350 dosnt come with appletalk in the software. IC-401 Is the model number of the controller you will need to connect the c350 to any kind of mac for printing / scanning.
Mar 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
Aug 26, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350
If you are printing to a C350, a COLOUR MFP, you MUST have a controller to print from a Mac.
You can try using a Unix/Linux driver.
Have you tried:
http://help.bt.konicaminolta.ca
Aug 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
107 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
