Question about Goldstar DH504EL Dehumidifier
Ge pss25ngmd bb refrigerator wiring diagram
Need wiring diag
Posted by Robert Vincent on
I need a wiring diagram for an Ebac 880e dehumidifier
http://www.ebacusa.com/technical/Manuals/HD.pdf
Jun 29, 2010 | Ebac HD880 Dehumidifier
I have an old Sahara 25 dehumidifier need water collector chamber
I contacted GE on the web and found out they don't make the parts anymore for this unit. I used Gorilla glue to repair the cracks in the old semi soft plastic water collector chamber.
dmbrownpe
Jan 29, 2010 | GE Dehumidifiers
The coils on my dehumidifier are frosting over.
Are the coils clean? If it has a filter is it clean? If yes to both, it has lost (leaked) refrigerant and it's time to buy a new dehumidifier. If the leak can be found it probably wouldn't be repairable and would cost more to fix than it's worth.
May 05, 2009 | GE Dehumidifiers
What terminal on the capacitor gets the blue wire from the run terminal on the compressor? Does it go in the terminal with the white wire or the blue wire?
Follow the start wire from the compressor to the capacitor, the run wire will go to the opposite side.
For instance if the white wire is the start wire on your compressor then the run wire will go to blue wire and vice versa.
Apr 14, 2009 | Fedders A7DH45B2A Dehumidifier
I have a GE Dehumidifier, Model # AHK40LKG1, Serial # AM166016. Thus far we have used the bucket to empty it. We now want to use the hose attachment to empty it. I find that I have the clear plastic tube...
I have same problem (ie, missing this drain nozzle). From my searching, the GE part number is : WK09X10006.
Found it on : http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
searching for 'drain nozzle'.
My searching (so far) is finding a couple places online to purchase this, but at $14-$15. Still looking for a better (ie, cheaper!) option.
Hope this helps.
Jul 25, 2008 | GE AHG40LJ Dehumidifier
Goldstar DH504EL Dehumidifier Logo
63 people viewed this question
Top Goldstar Dehumidifiers Experts
Bill Long
bobalix
Marvin
Marvin
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
