Question about Panasonic PT-47WX49 47" Rear Projection Television
JVC AV-65WP74 turns on and blue power light flashes fast but no picture and no sound
Posted by Cameron Bagley on
Kenneth Lee Sr.
  • 597 Answers
COUNT # OF BLINKS AND SEQUENCE...CONTACT JVC TECH SUPPORT. IF YOU DECIDE TO REPAIR, LOCATE HONEST TV TECH
Posted on Feb 03, 2014
Power light come on but no picture also there is a faint ticking sound
Convergence output Ic's and check associated low ohm resisters, replace any that are open.
Dec 06, 2013 | JVC AV-65WP74 Rear Projection Television
Flashing green power light
If the model indicated here is right It could be in the power supply and this model sometimes fails where light just blinks--that could be also convergence issue--in this model there is a way to disconnect the power going to the convergence board to see if set will then turn on.
Jun 14, 2012 | JVC AV-65WP74 Rear Projection Television
I have a JVC AV-65WP74, I went to bed watching the TV then turned it off for the night but the next day when I turned it back on the blue light came on on the TV but no picture, the TV makes a fast...
The clicking you hear is probably caused by a relay that controls the incoming AC to the main power supply. This is a protective reaction to a problem in the power supply itself or an overload due to a failure downstream from the supply. This is not a likely DIY repair. You will probably need a technician to determine which of these two likely problems it is.
May 19, 2011 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 clicks and sounds like a heart beating and then turns off. what is the problem, how much will a repair cost?
it could either be convergence ics shorted or deflection board trouble
as to cost convergence 300 to 350
if its power supply 300.400
it would have to be isolated down to the exact location causing the problem
but usualy a great set to keep around
Oct 24, 2009 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74
Hi, sounds like your convergence IC`s have failed if one of the colors doesn`t adjust either up/down
or left/right. If you have soldering equipment and are very proficient at soldering you can replace them. if not you definitely need to call a tv tech, if you need more info ask away, video-tek
Jan 26, 2009 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74
You can get eplacement CRTs ( picture tubes ) for your model at the following link.
http://servicemanuals.vstore.ca/
Aug 09, 2008 | JVC AV-65WP74 Rear Projection Television
JVC AV_65WP74
This model is full of problems, I had the same reapir done abput 2 years ago and now my convergence is shot. either fix it yourself or throw it out!
It was such a nice tv while it worked.
Jul 02, 2008 | JVC AV-65WP74 Rear Projection Television
Flashing power light on JVC 48W TV
Tri to remove the concergence pcb assy and start the Tv.If the TV is working just replace the convergance IC.
Feb 11, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-65WP74 65 in. Rear Projection... Problem:
I'm having a problem with my JVC 65WP74 the screen shows double pictures at the top and in the middle.
Oct 10, 2007 | JVC AV-65WP55 65" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
67 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
