Cars & Trucks Logo
A
Anonymous Posted on Jun 06, 2017
Peugeot 307 door lock
Recently my Peugot 307 developed an issue where using the key fob, my drivers door remained locked, I had to lock again and unlock with the key fob for it to open. This has developed to the point where i can only open my drivers door with the key (which still unlocks all the other doors) and yet the key fob still works to lock the drivers door. I have literally no idea what problem, or combination of problems could have caused this, any help would be extremely appreciated :)
Bill George
Level 3:
  • Cars & Trucks Master 2,517 Answers
  • Posted on Jun 06, 2017
Bill George
Level 3:
Answers
2517
Questions
Helped
543928
Points
7493
Probably the plastc clip the door lock rod goes thru broke.
2009 Expert. remote fob not working. The central locking will not work with the key, only the drivers door locks. Worried because I'll have to leave the van open over night.
Try replacing the FOB battery. Check the fuse for door locks. usually located in the engine bay fuse box. Temporarily you can lock the other doors from inside the van and lock the driver door last using the key. Another possibility is that the locking switch in the driver door is faulty or the central locking motor is. All other doors will only lock if the driver door locking system works. When you lock the driver door, the locking motor will hit a switch that will lock the other doors.
How to program key on peugeot 307 hdi 2001
put key in icnition turn on but don"t start engine,press door lock and hold for a few seconds,then turn off,key fob should now work,if not try again,also make sure you have the correct battery in key fob.
central locking working on vaccum system..trying getting it serviced..should sort out
1helpful
Key fob only opens drivers door
hit the unlock button twice. most fobs are programmed so you hit it once, drivers unlocks, and again for all the rest.
2answers
Peugot 406 central locking key fob not working have replaced batteries, failed to work after got wet in rain
if you got the FOB really wet then the circuit board is ruined, you are going to have to replace it.
2helpful
2answers
307 central locking fault
If you have replaced the battery and the ecu wasn't in sleep mode, then you'll lose the synchronisation between immobiliser and fob. go to peugeot dealer or call out a car locksmith who then can reprogram your fob with car ecu. I have read the method in internet but not sure what the steps were. you can google it may be you'll find it.
20helpful
3answers
I need to reset my peugeot 406 key fob
Had same trouble with my 406, fixing no problem, with new battery in fob, insert into ignition, turn key, BUT DO NOT START ENGINE, hold button for about 10 seconds release button and remove key from ignition, then try and see if doors lock on remote, if not try again, had to do this a couple of times, and it worked, sorry to say that now my key fob button has completely fell apart, through ware and tare
Central locking / door locks fault
http://www.honestjohn.co.uk/forum/post/?t=69400
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
