Question about UTStarcom Computers & Internet
Getting security key - UTStarcom Computers & Internet
Jun Salazar
    Habit-Forming:
  • 18 Answers
Http://www.dslreports.com/forum/remark,17021137
http://keison.co.uk/utstarcom/utstarcom_f1000.htm
Posted on Dec 30, 2014
How do I get the security key setting?
I see that you are looking for the security Key settings, to be able to get your security key settings fir the Router you will need to get your Routers IP address.
Step 1. click the stat button on the lower left side of your Desktop screen, click all programs and look for Accessories, then click command promp this should show a black screen with a blinking cursor type in ipconfig then press enter this will show you information about your networks ip address, Look for Default gateway something like this 192.168.2.1 this varies on the router that you have.
Step 2. Enter the IP address on the address Bar of your browser then press enter this should show you the Routers settings page that is where you can see your routers settings for the security key.
to see your security key in windows you will need to check in device manager and click open Network and sharing center.
Upper right hand side you should see Manage wireless networks, click on Manager wireless networks it will show you a list of wireless Routers that you laptop has connected to, in the list look for the Router that you are connecting to and double left click on it it show you a window click on security this will show yout the settings for your windows security but the security will be encrypted as dots, the above instructions will show you how to get the security key from the router to be able to enter it in your windows settings and make the security key on the Router and your windows the same .
I hope that I have answered your question about getting your security Key :)
Mar 24, 2011 | Linksys WRT120N Router
Im trying to get online on my xbox and i forgot my password to my router
If you have a WEP key or something, get on your computer and download this, then run it. It will tell you the key of all networks in range.
http://download.cnet.com/WirelessKeyView/3000-2092_4-10614187.html
Feb 07, 2011 | Belkin (F5D7230-4) Router (587009)
What does it mean by network security key
The name 'network security key' is itself self-explanatory. Every network has a security key and you will need this key to be a part of that network. Just as is the case of any other term that comes from the field of network engineering, there are a lot more details attached to this term, too. So, let us try to understand all the aspects related to network security key
An explanation as to why we need a wireless network security key is not even required. Still, if any one is skeptical about adding any complexity to their available wireless network, just think about it. Your wireless network range can be detected by any other computer with a wireless setup and that comes within the range of the network. So, without you knowing, it's very easy for any user to get connected to your wireless network and gain access to all the data that you intend to share only with those computers with which you have setup your wireless network. So, what is a wireless network security key and how is it useful in such situations?
Well, a network security key or passphrase is something like a password, which any user who wants to connect to your computer will require. But, I think that before we go into the details of figuring out, how to get network security key for wireless computer, we should take a look at the different methods of securing your wireless network
Oct 03, 2010 | Computers & Internet
Unable to connect to access point not the correct security key. need security key.
If you need to get Information about your Security key, you need to access the GUI of your access point of wireless router by connecting to it using the default gateway. Then after taht you can get into the page where you can get teh security key. Cheers!!!
Sep 02, 2010 | Computers & Internet
What is the security key of netgear wireless connection?
Security key in side the router. To get the key you need to access the routers web interface. Please follow the steps below on a wired pc. A pc which is directly connected with the netgear router using an Ethernet cable.
1. Open internet explorer and in the address box type http://192.168.0.1 and press enter. It should ask you a user name and password. User name is admin and password is the word password. click on login or ok.
If you don’t get user name and password window with http://192.168.0.1 and try http://192.168.1.1 or http://routerlogin.net
2. Click on wireless settings on the left hand side.
3. Under the security section if the security is wep then note down the key one and this is the security key you need.
If the security is something else then you wont be able to see the security key it will ******. In this i'll suggest you to change the security key to wep, encryption should be 64 bit and authentication type should be open. In the security key one box you need to type in the security key, The lenght of the key should be 10, you can only use a-f and 0-9. For example 123abc567f. and save the settings.
Try connecting on the wireless pc.
Note: if you change the security key then you need to connect all the wireless devices with the new key.
Hope this helps you!
Rashish.
Aug 16, 2010 | NetGear WGR614 Wireless Router
Car won't let me in.
if you have a key fob,try it. if not,then get under vehicle and follow battery cable from the starter toward the battery. you will run into a few wires in a bundle coming off that battery wire. this is where the security system is tapped to get power. cut those wires and then your key will work. its a temp fix,so get your security system looked at asap after doing this if you want the security.
Apr 29, 2010 | 2002 Mazda Protege
I need the security key how do i get it?
It is not possible to get same security key from anywhere if you forgot. You have to reset the security key by login in Modem.
Mar 11, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Brought a new laptop with wireless installed have a philips SNB5600 but have lost the security key how can i get the code
go to the wireless access point admin settings (not on your wireless adapter on your laptop). then check wireless security settings. if you see something there such as security key, that is the security key that you need to set up on your laptop. if security key is not visible, try to see if there is an option there which says unmask to show the security key, then copy it to your laptop. if all else fails, change the security key in the wireless access point and change all the wireless adapters that connect to it accordingly to the new security key you set it up.
Nov 07, 2009 | Computers & Internet
Hi i had to do a recovery,now i can not get access to the internet through my wireless conection.when i try to, it ask me for security key or passphrase can you help me solve this...
Hi, u have to tell the fone model and alsorefer ur fone manual to reslove this issue.. the security key that ur fone is asking mite be the security that ur wireless modem has..so u have to use the same security code or key..u can c that security key of ur wireless modem by typing in the default IP address of the modem u have..it owuld be written in the manual of the WIRELESS MODEM aswell..if ur able to note that security key i.e the WEP key,u can try putting that key in ur fone when it asks for the security key..then lets see what happens.
Jul 14, 2008 | ASUS Cell Phones
Computers & Internet Logo
204 people viewed this question
Top UTStarcom Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an UTStarcom Computer and Internet Expert? Answer questions, earn points and help others
