The "EP" error code on your refrigerator's display typically indicates a problem with the water pressure entering the ice maker. This can be caused by a few different issues, including:
Clogged water filter: If the water filter is clogged, it can reduce the water pressure entering the ice maker, causing the EP error code. Try replacing the water filter with a new one.
Restricted water supply line: If the water supply line is kinked or otherwise restricted, it can reduce the water pressure and cause the EP error code. Check the water supply line to make sure it is free of any kinks or restrictions.
Low water pressure: If the water pressure to your home is low, it can cause the EP error code. Check with your local water provider to see if there are any known issues with low water pressure in your area.
Ice maker valve: The water inlet valve that supplies water to the ice maker may be faulty. If the valve is not opening or closing properly, it can cause the EP error code. You may need to have the valve replaced by a professional.
If you are unable to resolve the issue on your own, it may be best to contact a professional appliance repair service for assistance.
Hi Santhosh, a PE error code is a water level/pressure switch problem. Could be one of three things. First,a bad wire from the control board to the pressure switch. Second,a clogged pressure tube from to tub to the pressure switch could be clogged. Remove tubing from the pressure switch and blow through it to make sure it's clear. Third is the pressure switch itself is bad and needs to be replaced. Hope that helps.
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
F-11 like a Kenmore means communication error between the motor control and the main control. Check connections, unplug and replug computer connections and see if problem persists. I've seen cases where either board or even both can be bad.
