Question about Apple iPad Tablets & eReaders
Download ios I wanna download and installing this app
Hampi Hemp
  • Apple Master
  • 706 Answers
IOS is not an app - it is the running system of an iPad and is to be dowloaded from Apple:
- the download depends on the model of your iPad:
For the iPad first generation (A1219) to update is only possible with connecting the device to iTunes on a computer.
- but this model supports only iOS 5
- NO iOS 6/7/8
for all other models:
There are two ways to upgrade the iOS version of your iPhone, iPad, or iPod Touch - via connecting the device to iTunes on a computer
- or directly from within the device, but only snce iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
Posted on Dec 27, 2014
I can't download any apps.its telling me I need to upgrade
Either the Operating System (IOS) on the tablet or the tablet hardware itself is too old to run the app(s). Check for and install an IOS update and try again. If the hardware (tablet) is too old, you'll have to replace it to install the app(s).
Sep 28, 2015 | Apple iPad (16 GB) WiFi Tablet PC
How can I open facebook
Facebook on old iPads with iOS 5.1.1:
It is possible, a bit tricky, but possible. First, you'll need to download the Facebook app through iTunes on your computer, this will make it show up as "purchased" in your library.
After that, open up the App Store on your iPhone and go to the 'purchased' tab. When you try to install it this way it will tell you that you need iOS 6 or higher, but will also ask if you would like to download an older version of the app. then click on download.
- again step by step:
1) Open up iTunes on your computer
2) Go to Store (left hand column) ->iTunes Store
3) Search for Facebook; - download the app
4) then open App Store on your iPhone
5) Click on 'Purchased'
- you will have to install Facebook by clicking on it as usual.
App Store will ask you: "Download an older version of this app. The current version requires iOS 6.0 or later, but you can download the last compatible version.",
- then click on Download and it should finally work.
Feb 08, 2015 | Apple iPad (16 GB) WiFi Tablet PC
How do I download free Netflix app that is compatible with apple ipad1 first generation iOS 5.1?
install netflix on ipad first gen.:
first make sure your iPad 1st. gen is on iOS 5.1.1 !
It is possible, a bit tricky, but possible. First, you'll need to download the Netflix app through iTunes on your computer, this will make it show up as "purchased" in your library. After that, open up the App Store on your iPad 1 and go to the 'purchased' tab. When you try to install it this way it will tell you that you need iOS 6 or higher, but will also ask if you would like to download an older version of the app. then click on download.
3) Search for Netflix; - download the app
4) then open App Store on your iPad
- you will have to install NetFlix by clicking on it as usual.
download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-0.jpg download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-2.jpg download-free-netflix-app-compatible-ucocffsbdgqp14shduy2nfxr-3-5.jpg
Sep 15, 2014 | Tablets & eReaders
How to download showbox app for ipad
Open Safari & go to this URL.
https://itunes.apple.com/sg/app/showbox/id793056594?mt=8
bobwin
Aug 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Download ios 7
For the iPad first generation (A1219) before iOS 5 to update is only possible with connecting the device to iTunes on a computer. Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
- NO iOS 6/7/8 !
download-ios-7-idhgrcvb3gwnj1x0htsxmiux-1-0.jpg download-ios-7-idhgrcvb3gwnj1x0htsxmiux-1-2.jpg download-ios-7-idhgrcvb3gwnj1x0htsxmiux-1-5.jpg
Jun 27, 2014 | Tablets & eReaders
Ios 6 download install can I install this app
on a 1.gen. iPad it is impossible to install iOS6:
this model supports only iOS 5 !
- NO iOS 6/7/8
- the processor is too slow....
- NO iOS 6/7/8 !
ios-6-download-install-install-app-puadae1tafe2snbdqkdlrrgh-2-0.jpg ios-6-download-install-install-app-puadae1tafe2snbdqkdlrrgh-2-2.jpg ios-6-download-install-install-app-puadae1tafe2snbdqkdlrrgh-2-5.jpg
May 17, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Remove baidu from iPad
Have you installed a Baidu app on your iPad and wanna remove it?
Well, the first method recommended for you is to directly delete apps from Home screen on your iPad.
1. You only need to keep touching the icon of the app until it wiggles with an X at the upper left corner.
2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the apps deleted with no efforts.
Sometimes you cannot see the X and don't know how to delete apps on iPad directly, you can check the Settings at this moment. Then you can try to delete the apps on your iPad again.
1. Check the "Settings", then scroll down a bit and tap on the "General" option.
2. Tap on "Usage" (older version of iOS) or tap on the "Storage & iCloud Usage" (newer version of iOS).
3. You need to tap on "Manage Storage" and you'll see a list of all app installed on your iPad. Simply select the app and tap on "Delete" to delete that app.
There are also some other methods to help you remove unwanted apps from your iOS device. Click the following link to know more.
How to Delete Apps from iPad
Dec 09, 2013 | Tablets & eReaders
I can't install the million second quiz show app because I need iOS 5
You will not be able to install if the app requires a certain version of the operating system. I would also suggest updating your device to the latest version of iOS 7 which is 7.0.3 which would also allow you to install the app.
You can learn more about iOS 7 at http://www.apple.com/ios/
Hope that helps!
Sep 16, 2013 | Apple iPad 64 GB WiFi
Tablets & eReaders Logo
638 people viewed this question
Top Apple Tablets & eReaders Experts
gaucherre
Shaukat Bhutto
Shaukat Bhutto
Nicola Conroy
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
