Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Cleanning projection tv - Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Bryon Conner
    New Friend:
Have a yellow spot on right corner of picture on wega lcd
Posted on Aug 11, 2015
Hitachi projection tv mirror problems
the mirror in projection tv, needs to be cleaned along with the lenses for each crt clean them both and your tv will look like new good luck, butler
Oct 02, 2016 | Hitachi Televison & Video
How to clean lens on rca projection tv model# p61960 ?
Unless something got spilled inside the TV, I suggest you think otherwise about cleaning inside the TV. You will only make things worse by doing so.
Aug 21, 2014 | Televison & Video
REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Jan 26, 2009 | Sony KP-43HT20 43" Rear Projection...
PROJECTION TV'S & DLP TV'S
No, your DLP does not need the annual cleaning as your old projection tv did. The rear projection used high voltage, 35kv, which attracted dust and smog. I would recommend to have your DLP cleaned when your LAMP goes out. Your lamp should last 2-3 years, then I would call a factory authorized service dealer to replace your DLP's lamp and have them do the cleaning at that time. I do it everyday as a in-home service tech.I hope this help.
Jun 11, 2008 | Televison & Video
Cleaning tv screen
need to know how to clean a hitachi rear projection screen tv
Mar 05, 2008 | Hitachi 61SDX01B 61" Rear Projection...
How to clean 50 in rear projection tv
For the screen Philips make projection screen cleaner this is a spray with brush that is made for cleaning tv. The CRT's you can use some type of glass cleaner, not to waste on board.
Oct 05, 2007 | Philips 50P8341 50" Rear Projection...
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Open Questions:
See all Sony Grand WEGA KDF-60XBR950 60" Rear Projection Questions
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
