Question about D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n
Cannot access d link dao 1360 setup page - D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n
1 Related Answer
akgamit
Amit Gupta
  • 59 Answers
SOURCE: wireless access point Pda 1360
To perform a reset, please follow the steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Note: Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults including IP address, username and password.
Posted on May 29, 2010
Configure dap-1360 range extender
I THINK you are asking about a D-LINK dap-1360 range extender IF so see THIS YOUTUBE:
How to Configure Link DAP 1360 Wireless Range Extender
Be SURE to see this:
dap 1360 range extender Google Search
And this one too...
DAP 1360 Configure as repeater
NOT in English but lots in life is not... You can STILL see his setup steps clearly!
Anthony
Apr 17, 2018 | Computers & Internet
How to change password?
If you can't remember the password, follow these directions to reset the access point to factory default. You can then log in with a username of admin and a blank password.
DAP 1360 Wifi Access Point Hard Reset PCingredient
If you know the current password, just log in and change it on this page
http://www.support.dlink.com/emulators/dap1360/101/tools_admin.htm
Nov 09, 2015 | D-Link DAP-1360 Wireless-N Range Extender...
Why i can not go to sit for configure DAP-1360
Go to this link http://support.dlink.com/ProductInfo.aspx?m=DAP-1360 and download the user manual for your DAP-1360. Configure it in the WISP mode following the manuals instructions.
May 19, 2014 | D-Link DAP1360 IEEE 80211n (draft)...
JE NE PEUX PAS INSTALER DAP 1360
Access D-Link's support-site: ftp://ftp2.dlink.com/PRODUCTS/DAP-1360/
Choose 'REV. A' or 'REV. B' or 'REV.C'.
Download the instructions for your router.
Feb 16, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
How to configure Dlink DAP-1360 wireless N Range
Is this the router that is currently connected to your network, and also the router that is providing you with internet right now? what would you like to setup?
Dec 18, 2012 | D-Link DAP-1360 Wireless N Range Extender
Can't configure the network with ethernet cable
Hey, you're almost there. The connection between the no-wireless PC over ethernet to the DAP-1360 Repeater is fine. The reason it can't connect to your LAN or the internet, however, is that the repeater isn't actually repeating your Ofir network, it is instead creating it's own, completely isolated wireless network (Ofir_EXT).
The D-Link setup and documentation is confusing, and doesn't have proper instructions for the repeater setup.
Rerun the setup wizard, setup as a repeater, then select manual configuration method.
Now, enter the wireless network name of your the network you want to extend (in this case, Ofir). Then enter the same security and password etc. for Ofir in the following fields, just like you were connecting to Ofir from a smartphone or laptop.
Once that is finished, you should be up and running. If things worked, you should NOT see any new wireless network. There should be Ofir and just Ofir. Wireless repeaters work invisibly, you'll still connect to the same network like you always did, but now it will have much improved range thanks to the DAP-1360. The computer entherneted to it should be networked on the wireless LAN and have internet access after this as well.
Good luck, I hope my instructions were clear. Wifi networking is easy, it's understanding all the manufacturers less-than-intuitive software that makes it hard.
Oct 16, 2012 | D-LINK SYSTEMS DAP-1360 Wireless N Range...
Router can't detect DAP 1360 when installed about 90 meters away. UTP connectors tested okay.
have you tried turning on and off the router and AP? it would scan again...it looks like you just need to recheck connections and powers...
Oct 09, 2012 | D-Link DAP-1360 Wireless N Range Extender
D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n Logo
56 people viewed this question
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
