SOURCE: Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
SOURCE: I can't find a driver to install my labtec LCS 2424 speakers
You plug it into the headphone socket on the laptop
SOURCE: my speakers quit working. my
if your computer came with a disk the sounds drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
SOURCE: windows vista ultimate doesn't recognize my
Being windows vista is most likely is a driver problem. Is it internal or external sound system, not the card that works. If the manufacturer does not have an updated driver by now you can set the device to work like windows xp and it should only effect that device. Also search the web there are driver packs out there for windows vista, keep in mind its all the drivers for everything on one large compressed file so it should be a large file size.
Ultimately I would say upgrade to windows 7, its how windows vista should have worked. I have devices from windows 98 that work on win7 no problems. Vista was just very premature in its release. Hope this can help. Sorry for my bad spelling.
