Any router should work with any modem. Make sure you are running an ethernet cable from the WAN/Uplink port of the router to the modem, or in some cases it will be a USB cable. Also you can test your internet connection by plugging a computer directly into the modem.
pls friend for unlock code to browse free on mtn wimax moderm bm328 model. i will be glade if u help ur fans my email [email protected] lives in cameroon
Usually you would need to restart your cable modem or dsl modem anytime you switch or reconnect. Unplug the modem for 20-30 seconds, then restart the router. You should me good to go after that.
Good luck!!
EJ
Ok...don't panic....take it all back out thru control panel>add/remove...reset your wimax modem by the little reset hole in the back as this can be an issue sometimes by adding the modem in the incorrect order. You should install everything but the "lan" cord from modem to modem last. A good test is to take the "lan" cord from your winmax modem and plug it right into your pc and you should have internet.
